iFreilicht
- Sep 23, 2014
Good start! Now for all the other little details that need figuring out
What EMI concerns? You get more EMI created when you microwave a burrito or while sexting a chic you met on Tinder. I doubt he has any other appliances in the area that are affected.Couldn't you reduce the EMI concerns and provide it some protection with just a simple mesh covering? It would still essentially be open air. Even just screwing on a couple gridwall panels.
If this was a true honest to god workstation, then it would have ECC RAM and a full blown case to deal with EMI concerns. It isn't a mission critical computer worried about that one-in-ten to the trillionth chance of an errant cosmic ray getting past the earth's magnetic field, through the atmosphere, and hitting a square millimeter section of RAM causing it to flip a bit and blue screen.
This isn't a workstation. It's an artpiece that probably plays video games and doesn't run anything mission critical. It's fine in it's current configuration. OP's only concern should be curious pets or if he decides to pick it up while wearing wool socks on carpet in the middle of a zero humidity winter.
I've run open air computers for years with zero issues. A lot of the bit coin miners and other distributed computing guys run open air systems with zero issues. I don't see a tiny SFF setup like this being of any concern.
First off, how dare you assume I eat burritos or am into chicks. For all you know, I am a raging homosexual raw food vegan. That out of the way, I'd still have a concern about protecting the equipment from accidental damage from even a small bump. Personally, I have two cats, so screwing on a couple lightweight gridwalls would make sense.What EMI concerns? You get more EMI created when you microwave a burrito or while sexting a chic you met on Tinder.
I have a short ribbon cable that allows the video card to be mounted parallel to the mobo for a very slim form factor... hasn't crapped out yet. *knock on wood*Runamok81 said:There have been a few folks on this forum whom used PCIe riser cables to produce unique form factors.
Lol. I like this guy.First off, how dare you assume I eat burritos or am into chicks. For all you know, I am a raging homosexual raw food vegan.
Those may be your concerns, but not OP's. I don't think this thing is going into mass production. As a one off mod, I think it's a brilliant piece of functional art and I think adding anything to the exterior would completely kill the point of the mod in the first place.Ducman69 said:That out of the way, I'd still have a concern about protecting the equipment from accidental damage from even a small bump. Personally, I have two cats, so screwing on a couple lightweight gridwalls would make sense.
Re-reading the thread, I'm not sure if you were referring to the EMI issue with the PCIe ribbon cable or EMI and the rest of the machine. If OP is using a decent quality shielded PCIe ribbon cable I think he will be just fine.
You could possibly make your own shield by just combining duct tape and aluminum tape, which most of us have in the house.But he doesn't. He uses an ultra-cheap non-shielded grey ribbon cable. But somehow it works for him.
Well I like it. I love being able to SEE all the goodies right out in the open.
