no2censorship
- Oct 20, 2008
Had it for about 2 months and possibly a week more or less; never tried to feel for exhausted air from the fan when gaming, but is it normal that the fan has basically never turned on the many times i couldn't feel air coming out since the 1st time I've used it?
CPU usage is high and has always ran unusually hot for what it is; CPU usage often goes up to 78% if you keep circling the mouse cursor around on the desktop without any tabs even in the taskbar. Every time you open something it generally uses at least 38%, sometimes as high as 84%.
If the usb ports are on the 3.3V rail and if the CPU draws a little from the 3.3V then it's definitely my psu; what draws from the 5 V rail? (perfect; only one 12V rail has been shown with asus pc probe and bios has risen to going from 12.01 to when I just checked it was 12.20, 12.23, 12.25 and went back in forth from those every 6-9 seconds, so like the tru frame rate issues described below it doesn't go back and forth rapidly more like every 6-9 seconds or so; more like 4 seconds for the tru framerate), then I'd conclude it's the psu; even if it's in spec limits (I don't know) it was no where close to perfect like it was the last time I checked in the BIOS, about 9 days ago; it's a constant 3.47V, which is about ~5% way off from what mine was and what the reviewer from johnny guru was.
I'm using a 14 gauge power cord from PC power & cooling by linetek; it came with a 16 gauge one by linetek; could somehow be getting too much current from the wall with a really thick power cord for a PSU that could would probably be fine with an 18 guage? I had to have a 14 guage one, because I'm a spec whore.
Audio seems extremely clear, consistently. DX is in last slot down, so it's very close to the sound card; is it likely that the DX would be giving EMI to the PSU?
System hardware config has been the same since i've had it.
I've heard that Antec products aren't very often DOA, but that they die early. Would the latter be likely or known to apply to the sig 650?
any details i left out, let me know. I kind of really need some help quick, if possible=] Thanks to all who reply in advance.
I'm think the reason tru's frame rate is like from like 57 occasionally then it constant changes between 45 and like 25, it basically goes back and forth from playable (as high as 57) to unplayable as low as 25; changing graphics setting makes zero difference other than the image quality of the slide show.
Possibly Slight graphics corruption, in the form of an usually shaped large horizontal (with a circle on top of it) white bar blanking. when refreshing the Hardforum page; Task bar messed up 3 days ago, but it was easilly fixable; it was an issue with dx control panel refusing to show up and it was also fucking with the task bar which could be fixed easily.
No BSODs the whole time i've had it. Does that point out that it likely isn't any other component?
last notes: in HW monitor the voltage readings and what they're for are completely unfamiliar, including the vcore messed up. I know HW monitor isn't accurate, but I have no idea what they measure, because I've never heard of them.
CPU temps are consistent between pc probe and everything else;
PC probe and the bios give me a 1.45 Vcore for my kuma, for whatever that's worth.
I don't have multi-meter, and I'm not going to use one, because I don't know that it's necessary to consider.
My 9800gtx+ is running a few deg C hotter under the same conditions and the fan speed was 31% when the temps were low. Since they jumped 3-5C the fan speed's 1st increase was to 35%, now it's to 39%. Different version of evga precision than at first.
is a later version of precision known to give different results than the version before it?
