Originally posted by kill_emma
one word of advice, post the pics.
Originally posted by theNoid
shuttle cases aren't meant for oc at all. If you want to oc your vcard dont use your shuttle case. looks very clean tho.
There is a clip on the bottom of the drive tray to keep the hd cable away from the northbridge. The power cables do need a bit of work to look pretty, but it's easy to clean up with just a couple cable ties. Admittedly, some of the video cards with larger heatsinks might not fit in the Shuttle cases. People have fit 9800pros in Shuttles, but you just need to be careful which brand you get. Not sure what problem you had with the Audigy 2... that should have been fine.Originally posted by Icewindius
I just didn't like how the freaking HDD cable covers up the Northbridge fan pretty much and the disk drive cables runs across the top and the interior got scratched so freaking easily just be rubbing my fingers on it, the power connects run all over the place.......Arrrrgh was just fustrating as hell. And then after all that, my Audigy 2 and Hercules 9800pro didn't fit worth a damn. Boy I was pissed
Ugh, no thanks. I can see why their popular but i'll just be staying away from them.
