Depends on if you mean from a PC or from a Blu-ray directly. From a PC, sure, no problem. You won't actually play the 1080p video in 1920x1080, the monitor will be getting a 1920x1200 signal from the computer, and the computer will just be letterboxing the video. What he means is that some monitors don't do well with an actual 1080 input. The BenQ FP241W I used to have was apparently notorious for that. Over certain connections, it stretched 1080 improperly.
My sympathies on the new monitor buying, always stressful when you have to buy blind. I went through the same thing not long ago. I wish I could be more definitive and tell you the One True Display, but I'd just be lying to you.
Haha, now with a determined hand on my mouse, I rushed to newegg only to find the DS out of stock! buy.com, amazon same thing! lmao.
Thanks for your help and everyone else's here. I'm going to just go with the DS, and return it if it's really that shitty. As for the 1080p playback, I would only be using it from the PC...so I wouldn't even be experiencing what you guys are speaking of.
Thanks once again, and I'll update you guys on my opinion of the panel (if it ever comes back in stock!)
