This debate just keeps on giving...
(It's so subjective depending on what one is looking for.)
Hi!
Phew, the monitor is surely expensive in Czechia. However, it is not so expensive in nearby GermanyI'm starting to seriously think about getting one. It the seller can guarantee no-dead pixels, I'd hate to spend loads of money to get dead pixels :-/
Anyway, I'd like to ask some quiestions:
1) So how does the monitor fare in games compared to better *VA monitors? It seems OK judging by your posts.
2) Is the pannel matter? How much?
3) What about the size, isn't it overhelming? I fear even 24" is very large, however I often need to have open at least two documents at once. Pixels are larger, aren't they?
4) Is the monitor quiet? No sounds from the power source?
5) Can you compare the input lag with some more *VA monitors? Which are faster, which are slower?
6) One last question/request: Please post some screens!
Thanks
1) The monitor is good for games, at least as good as that BenQ FP241W you tried out, Biges. The nice part is that the overdrive can be turned on or off
2) Panel size is the same as any other 24", but with a very small bezel around the panel
3) Same as any other 24", but with a slightly wider, but stable stand.
4) Very few people have complained about humming or whining from the thread that I went through.
5) Input lag is same as the BenQ FP241W, but less than most VA monitors. Not quite as good as TN monitors. It's rated around 22 to 40 ms, with 40ms being fairly rare.
You can also read a review here:
http://xtknight.50webs.com/lcd26/
One thing you will see is that the anti-glare coating on this monitor is not all dirty, grainy or sparkly, as I remember that's why you bought the BenQ, due to lower anti-glare than average.
I'll post some photos when my unit comes in. I'm hoping TOMORROW.
Regards,
10e
And from that review, the one thing that would have me get the 2490 instead:
"Cons: Not the best option for sRGB users (colors oversaturated in general use)."
I really can't see the point of spending that much money for a super accurate, 12bit LUT internally calibrated monitor that will end up being inaccurate most of the time, because it will be running in the wrong gamut. Accurate in photoshop, Disney the rest of the time. PC color management is a mess.
OTOH, the 2490 is sRGB and once you internally calibrate it, it will work across all applications/games/movies etc, even Linux (I dual boot).
So I think the question is whether you want absolute accuracy to the sRGB standard, or the best looking colour. There's no one right answer for that, but the idea that the 2690 is bad because of a wider gamut is false.
As I've said, I think it is an advantage in games because it looks better. That's the only standard I use for games. Games aren't designed to try and have some optimal look, they can't be due to the incredibly wide variety of graphics cards they are called to run on. So I'm not concerned with hitting a certain standard, just with looking good, and it does look good in games.
It seems to me your opinion is more based on a standard of artificial purity, that somehow achieving the most "correct" image by some artificial standard is the best. I encounter the same thing all the time with people and audio. They are so concerned with getting a bit-accurate playback of the original material. Ok, that's fine if you are mastering a recording, but if you are just listening, you should do whatever sounds good. If that means applying EQ, then do it. Who care about accuracy? If it sounds good, it is good.
Also calling a wider gamut "wrong" is extremely ignorant. sRGB is not the One True Colourspace(tm). There are lots out there, and indeed pros often work in a number of different ones.
Exactly, absolutely - you are describing 2490.Colour
Hands down, best colour I've seen on a display. Better than CRTs, better than my old LCD (A BenQ FP241W).
Closer to reality than what? Aren't as washed out as on what?Wide Gamut
...To my it looks more vibrant and closer to reality. Things aren't as washed out.
I do not have colors on my 2490 better or worse than on 2690.So while photo or video people might have a problem with the higher gamut, for gamers I think it is a huge boon.
This review desperately needs more pictures of the LCD and less chatter.
I just like seeing a few nice high resolution photos taken of a product in a real life surrounding such as the persons desk when I look at a review so that I can get more of a feel of the product.
Oh, I see.
I think 10e will add a kind of those.
Sorry to hear, 10e
I just bought mine last night with next day shipping. Hopefully I'll get a good one and will enjoy using it all this weekend. (bought it from Amazon.com)
I'll make sure to come back with my own experience.
(god I hope it comes in before the weekend. What good is a shiny new toy on a Monday night?)
Hi! So I was finally able to borrow this monitor.
I see the color saturation is dicussed a lot here, so I'd like to ask, if there is a way how to *reduce* it (it is no problem to increase it :-/ ). So far is seems it is not possibleI'm no artist or so, but these color are relly over-saturated even for general use.
Secondly, it is normal, that the power source produces slight "hum". It is the same sound as woth a faulty light tube
Thanks
There are different color modes that you can try.
There is an sRGB color mode in the same menu as "Programmable", "Native", etc...
It does dial down the saturation and gives fairly good color quality, equivalent or better to most monitors' preset sRGB modes. The only issue with this mode is that it is not a mode that you can calibrate with SpectraView II software.
I don't get any noise on my monitor whatsoever. I would think that it might be defective.
The one I currently have is revision 4F and build date of February 2008.
Regards,
10e
Am I able to use the SpectraView calibration software/hardware on my plasma tv?
any idea?
