- Apr 5, 2007
Since I'm in the CLI doing the install it just puts it onscreen right in the middle of whatever you're doing. So like I can be in the middle of typing a command and it will output 4 or 5 lines of error message.
It looks like they just rolled out Arch 5.0.6 and while my old install USB stick was generating the error message, it doesn't seem to be doing it once the install is up and running.
I guess I'll need to redo my install stick.
Nouveau is definitely loading. I've tried blacklisting it 2 ways but it still loads.
How would you recommend I blacklist the nouveau driver from loading?
I tried using nouveau_blacklist.conf in /etc/modprobe.d and nvidia.conf in /usr/lib/modprobe.d and neither worked to block it.
You are running the mkinitcpio -p linux command after blacklisting right?
sudo pacman -Rc xf86-video-nouveau
Try that too to eliminate the driver completely before reboot after blacklisting.
