My 1080 ti Fe - Timespy -normal or not?
Discussion in 'nVidia Flavor' started by mgty23, Mar 20, 2017.
  1. mgty23
    mgty23 [H]Lite
    107
    Mar 16, 2017
    Hi. I get my 1080 Ti Fe stock fan blower. My 3dmark time spy result:
    [​IMG]
    Normal or too low? 6700K cpu stock. Monitor weak 1920x1080 144hz. Temps 84C boost throttle a little.
  2. Etherton
    Etherton Will Bang for Poof
    6,781
    Aug 7, 2006
    That's what mine hit. Not OC, just stock speeds on the GPU. 4k resolution though.
  3. Supercharged_Z06
    Supercharged_Z06 [H]ard|Gawd
    1,905
    Nov 13, 2006
    Most likely throttling a bit, but you are in the ball park. An OC and better cooling would get you closer to 9K, if not over. I'm on a Titan XP and an older cpu, but water blocked so no throttling due to temps and I pull a score of 9500.
  4. MrSteel74
    MrSteel74 [H]ard|Gawd
    1,566
    Nov 17, 2000
    4790K, 1080TI at 1440P with stock clocks on the CPU and GPU and I scored 8234 or something along those lines.
  5. Darkswordz
    Darkswordz Limp Gawd
    416
    Jan 5, 2016
    Seems about right. My score with 1080Ti at stock and with my 6800K @ 4.3Ghz was 9,346.
  6. Mister E
    Mister E ?
    2,548
    Sep 14, 2004
    Maybe you should just play your games and stop worrying about worthless benchmark scores and then posting 800 different threads crying about it.
    Armenius likes this.
  7. craigdt
    craigdt Gawd
    514
    Oct 27, 2016
    Im a huge numbers guy, and I like running benchmarks as much as the next person, but I tend to agree.
    But there are also people who enjoy building machines just "because", so I can sorta understand
    Vellinious and Ocellaris like this.
  8. Vellinious
    Vellinious n00bie
    53
    Oct 23, 2015
    Maybe you should just stop posting on threads about benchmark scores, instead of posting 800 different times crying about those that do.
    Just a thought... /smack
  9. Armenius
    Armenius [H]ardForum Junkie
    12,896
    Jan 28, 2014
    The OP is a known troll who does this all the time when a new high end card is released. And he doesn't just do it here. He also posts as sew282 on EVGA's forum, and uses a similar 3-letter, 3-number username across other websites.
    Mister E is just responding in kind. If the OP is to be believed he has RMA'd at least a dozen 980 Ti.
  10. Vellinious
    Vellinious n00bie
    53
    Oct 23, 2015
    ....and.....
    I'm just commenting on the absurdity of posting a complaint, about someone complaining. Why bother.....
  11. Mister E
    Mister E ?
    2,548
    Sep 14, 2004
    By commenting you mean complaining, right? You see the stupidity of what you did now I'm sure.
    Algrim and Dayaks like this.
