Mortal Shell 2
Harbingers,​
Since our full launch last week, we have been overwhelmed by the response and all the experiences you've shared with the team.
Today marks the first major patch for Mortal Shell II, bringing new content alongside extensive fixes, performance improvements, combat refinements, and much more.
Among the additions are new Fragile Tarstones, a new way to respec your Shell, changes to the Glimpses and Tarcores economy, and new beacons and exploration adjustments that make navigating the world better paced. Ripostes have received a full scaling pass, numerous bosses and weapons have been refined, and we’ve made extensive fixes and optimizations across the game.
The full breakdown is below, but be wary that there may be spoilers present in this changelog.
New Items
  • Fragile Tarstones - A new class of Tarstone which breaks after losing durability. When breaking, they also yield a tarcore.
  • Glimpse Stone - Wears down as you defeat enemies, then breaks into Glimpses
  • Egon's Stone - Revive at the entrance of a dungeon at the cost of its durability, and when it breaks it prevents Gloom loss for that death.
  • Justicar’s Stone and Gloombound Stone are now fragile, have increased passive effects and added on break effects. Fragile Tarstones are not unique and can be found multiple times during a playthrough. Existing copies of Jusicar’s and Gloombound have been converted to Fragile.
  • Certain enemies now drop the new fragile Tarstones, several dungeons now reward them, and Merrick has taken an interest in selling them.
Economy​
  • Glimpses and Tarcores are no longer finite resources, allowing all shells and Tarstones to be upgraded in a single playthrough.
  • Mether's Severance is a shell respec item which can be given to Zhirelle, the shell keeper. In exchange she will sever your bond with a Shell, resetting it and granting you all spent glimpses back.
  • Tarstones now yield more tarcores when broken. If your save already has leveled up Tarstones, you’ll find a compensatory cache of Tarcores in your inventory.
  • Tarstones and Mether’s Severance can be purchased from Merrick and will restock occasionally when progressing through the game.
Exploration​
We’ve improved exploration flow, while adding new secrets for you to discover.
  • New Beacons have appeared throughout Fainweald and Mammon, but are only active during the day.
  • Two new cosmetic rewards can be found in the world once completing certain questlines.
  • New items have been added to the world, and some problematic chests have been reset.
  • Egon's Stone can revive you at a dungeon's entrance when you die inside it, and spares your Gloom for that death when it breaks.
  • A teleporter now appears in one dungeon after the Grisha pit fight, removing the walk back entirely.
  • You still haven’t found the second Trollweed.
Rewards and Economy​
  • We have changed how many Tarcores a Tarstone returns when tempered, so anyone who leveled up Tarstones before this patch will find some additional tarcores in their inventory to make up the difference.
  • Merrick's stock has expanded, with Glimpse Stones, Egon's Stones and Tarcores once you have gathered enough Ova. The Collector now carries Tarcores as well.
  • Dungeon reward chests across the first two regions have been revised, reward placement in Mammon has been updated, and missing rewards in the arena dungeons restored. Some reward chests in the world have been replaced with straightforward pickups.
  • Additional rewards, including Glimpses, added to the gloom siphon.
  • Mini-Beacons no longer award a Glimpse.
Weapons, Items and Balance​
  • Obsidian Hammer has had a full balance pass and now hits substantially harder.
  • The Great Martyr's Blade deals more damage. It was a pity it didn’t actually make it in the last patch, to make up for it, it’s even stronger now.
  • Heavy weapons in general have had a poise and damage pass.
  • Salvaged Trebuchaxe: Tiltshot has been redesigned. It was simultaneously overpowered and broken.
  • Axatana: its weapon ability now grants invulnerability frames and inflicts Fragile stacks, and its combat Tarstone active triggers correctly.
  • Weltcap is stronger in both its active and passive forms.
  • Base aggression and disengage ranges have been retuned across the game. Fixed enemies ignoring you while walking to a patrol point, retreating unreasonably far when unable to reposition, and being unable to attack while locked onto a different target.
  • Fixed Tarstones continuing to gather experience after reaching maximum level, and missing tooltips on a number of Tarstones.
  • Environmental status hazards have been reworked, including a new handler for Stasis.
Shells​
  • Eredrim: Shoulder Bash no longer leaves your primary weapon permanently stowed.
  • Proxima: the same fix applies to Biosampler, she can no longer become stuck in her hook shot, and an arm that was being pulled unnaturally straight has been corrected.
  • Genessa: dashes have been fixed, including the corrupted version.
  • Losing a Shell no longer breaks her paired animations, and her Intangible upgrade now works during grab attacks
  • Fixed astral copies drifting away from their intended target.
  • Doubles select targets better and switch targets when their original dies, rather than standing idle.
  • Smert: can destroy projectiles while in permanent fight stance.
  • Gragu: the Heart of Vatra no longer trails after you in sheep form, and his helmet uses the correct material.
  • Blood now marks Shell skins correctly across the roster.
  • Fixed Shell summon interactions, and Tarstone summons occasionally targeting you.
Bosses and Minibosses​
Most bosses in the game have received a general polish pass and bugfixes.
  • in particular has received a broad combat polish and bugfix pass. Its laser and spin attacks now have more consistent, readable timings and do not spam (this was a bug). We’ve also refined animation timings, adjusted bad hitboxes and fixed a nasty bug which was causing it to deal double damage on certain hits.
  • Tail grab no longer simultaneously takes both the Shell and Harbinger from 100-0. We heard some of you don’t like getting one-shotted, for whatever reason. In night mode it’s ON, though.
  • Ring Waves align to the ground properly and his elemental stomps have new effects.
  • no longer launches you, or himself, across the arena. He now uses the finished walk animation rather than the placeholder that shipped, his bite anticipation has been retimed, his riposte no longer wobbles as it begins, and a rare case of endless blood effects has been fixed.
  • has had his arena navigation repaired, his riposte alignment and physical hit reactions corrected, and a substantial visual pass over his fire and snowfall effects that also improve performance.
  • has had his arena navigation repaired, a stray lunge removed from one second-phase attack, and his phase transition riposte fixed against a wall.
  • deals considerably more splash damage with his area attack, can no longer interrupt his own shooting attack, and has had one attack retimed to be fairer. His arena is smaller and its beacon light is lit by default, which makes the fight far easier to read. He can no longer wedge himself into the environment during his dive.
  • was displaying the wrong name in game, which has been corrected. Stray effects have been removed from his death animations, the fire on his axe no longer flickers.
  • has had his attack and riposte alignment improved.
  • no longer interrupts his own sword throw, and will reliably pick his sword back up.
  • and
    have both been reworked, with retuned attacks, new ice attacks and corrected effects.
    spin now gives a proper warning that it cannot be parried.
  • has new projectile vfx trails.
  • no longer rotates incorrectly during her charge.
  • no longer glitches when colliding with other enemies, no longer nudges you into the air when you are standing still, and has had its damage, turning and jump attacks retuned.
  • ranged attacks no longer miss without reason, and
    now teleports sensibly within his arena.
Bugs, Softlocks and Getting Stuck​
Fixed many places you could become trapped.
  • Fixed getting stuck near the closed castle gates
  • Fixed getting stuck in a church in the opening region
  • Fixed getting stuck in a house in the sunken village dungeon, inside
  • Fixed getting stuck in Castigator's Keep by walking through a wall
  • Fixed getting stuck in the snow on the approach to
    arena
  • Fixed getting stuck in a hole in the ground in Eredrim's castle jail
  • Collision holes, ground gaps and missing collision have been patched throughout the first two regions.
Softlocks and Lost Progress​
  • Fixed an interrupted save being able to destroy your save file. Saves are now written so that a crash or a sudden shutdown cannot leave you with nothing.
  • Fixed a bug with Vatra’s Temple where players would be locked out permanently after exploring the area.
  • Fixed a potential crash and softlock during Lazlo's Rekindle.
  • Fixed a softlock when speaking to the barkeep after Gragu's death but before collecting him.
  • Fixed a softlock if you were struck while inside Hilga's Cauldron, and the interface failing to return when you climbed out.
  • Fixed declining the cutscene at a Shell unlock leaving you invisible and invulnerable until you restarted.
Objects and Interactables​
  • Fixed an iron maiden that could trap you as it opened, a lift lever that snapped the lift back to its starting position, and a wooden lift that could kill you on the way up.
  • Fixed a chest that destroyed itself, several chests that became unreliable after loading a save, and offerings failing to register in a locked chest.
  • Fixed gates in the Temple of Vatra that could strand your Gloom somewhere you could not reach it, and corrupted gates that would not clear if approached from the sewers.
  • Fixed items in the opening region hidden inside collision, which made them impossible to pick up.
  • Fixed a ceiling collapse triggering at the wrong moment, and a light puzzle with two candles that had stopped being connected to it.
  • Sitting down (hopefully) no longer launches you into the sky, it never happened to us but we saw some of you go flying.
Encounters and Spawning​
  • Fixed enemies visible before they had spawned in several encounters, and spawn triggers that did not cover the enemies they were meant to.
  • Fixed being able to lure
    out of his arena, and being able to interact with a traversal point during a boss fight.
  • Fixed resting at one late Beacon drawing enemies onto you, and mis-referenced spawners in a late encounter.
  • Fixed an infinite Ossinite farm, an exploit that allowed unlimited healing, and shield-carrying enemies becoming effectively immortal against one type of projectile.
  • Fixed personal items being unavailable until a restart if you had played the prologue.
  • properly respawn when playing NG+.
We Found Out About the Grishas​
  • Fixed a Grisha that respawned indefinitely in one dungeon, astral Grishas spawning embedded in the floor, and enemies becoming stuck on geometry. (rip Grishamancer)
  • The Grisha PP item active is now stronger, its passive spawning has been fixed, and its summon no longer displays attack warnings intended for enemies.
Parrying, Dodging and Ripostes​
Ripostes have had a full pass.
  • Player riposte damage now scales with enemy health, so the damage keeps up properly with late game, NG+, and Night Mode.
  • Invulnerability windows are now consistent between ripostes, and last through to the end of the animation rather than expiring partway.
  • Many player riposte recoveries end sooner, so control returns to you faster.
  • Riposte animations across the entire enemy roster now behave when your back is to a wall, rather than sliding you through it.
  • Riposte damage is now calculated and applied by the riposte itself, which resolves cases where it applied twice or not at all.
  • Fixed Proxima's riposte alignment against
Enemy Tracking and Hit Detection​
  • Enemy tracking and magnetism maximums have been restricted, and will continue to be adjusted on an individual basis in future patches.
  • Fixed projectiles that failed to register against enemy weak points, and sidearm projectiles choosing the wrong target.
  • Fixed brigand shield collision that could launch you into the air, and projectiles failing to appear in the shield.
  • Several enemies, including Lithopods, now align to sloped ground correctly, and dungeon champions now stand on the ground.
  • Fallen wooden bridges are now easier to hit, and destructible carts use better collision.
  • Fixed corrosion failing to apply after a projectile had been reused.
Story, Characters and Scenes​
  • Characters no longer turn, stare, drift or fade at the wrong moment across a long list of scenes, including Rickart in The Search and Resignation, Eredrim in Immaculate Path, Tiel in The Bottle, and Vratko during his dance.
  • Fixed overlapping and skippable dialogue in several memories, and retimed voice and sound in The Vision, The Search and The Censer.
  • Fixed story moments taking too long to appear.
  • Milos no longer falls silent at random, and greets you properly before moving on.
  • Zhirelle's dialogue is now cleared before a memory begins.
  • Merrick, Vratko and Egon can no longer be interrupted while dying.
  • Franz's conversations now trigger in the correct order, and he returns to his crank after being interrupted.
  • Marigold no longer starts two conversations at once, and the barkeeper no longer speaks to you through the tavern wall.
  • Baghead can no longer be damaged, and his ending no longer unlocks early.
  • Grisha Hunters now hold their weapons, Grisha Pups have new reactions, and the Grisha Matron can be harmed by ranged weapons.
  • Larreth, the Brigand King now appears without his helmet, and his guards no longer vanish if you kill him first.
  • Ruk's greetings react to your progress, and his dialogue no longer remains on screen when you enter a boss fight.
  • Egon's interactions now refresh after offerings, and interaction problems with Gorf have been resolved.
  • Corrected a subtitle that did not match the recorded line in Ruk's dialogue about the Lost Child, along with a considerable number of typos and missing punctuation.
Interface and Map​
  • Weapon level now appears in the inventory slot.
  • Fixed the map offering objectives you had already completed.
  • Fixed the camera key appearing blank in the launcher on mouse and keyboard, and the interact key ignoring your rebinding.
  • Fixed resetting "hide subtitles" to its default hiding the subtitles instead.
  • Fixed the Change Shade option disappearing after opening the Change Masks menu.
  • Fixed overlapping text in the Shell revive message in Simplified Chinese, long Tarstone names colliding with the temper notification, panels and icons overlapping at higher interface scales, and misaligned details on Mether's Breath.
  • Added a tutorial scale setting, with a separate one for console, and polished a number of tutorials.
  • Clearer colorblind setting descriptions, an updated open gate icon, and proper icons when a mask unlocks.
Audio​
  • New riposte stingers, and restored missing riposte audio for the Bloodcursed Lithopod.
  • New sounds for Fragile Tarstones wearing down and breaking.
  • Enemies can now be given an audible warning for unparryable attacks.
  • Ambient sound no longer stacks when several sources overlap.
  • Village dance music no longer collapses to a single point as you approach.
  • You no longer continue bleating after transforming back from a sheep.
  • Reprocessed older voice recordings.
  • Added several missing sounds including the Marrow Keep elevator lever.
  • Fixed Lazlo's armor loop.
  • Fixed the saved audio device being selected at startup when it no longer exists.
  • New speaker presets.
Performance​
  • Fewer enemies in some of the busiest areas, where the crowd was costing frame rate rather than adding difficulty. Spawners in the dense prison area have been rebuilt.
  • Fixed the significant hitch shortly after the shader compilation screen. That work now happens while you are still in the menu.
  • Fixed the frame rate drop when cleansing tar gates.
  • Fixed flickering textures.
  • Several rounds of dungeon lighting optimisation, and optimisation passes over Droeg's effects, the final boss arena, lightning, village buildings, stairs, books and library interiors.
  • The arrow volleys in the final siege no longer arrive all at once.
  • Reduced background work across weapons, hit detection and movement, returning a meaningful amount of frame time on console.
  • Improved rendering of destructible objects.
  • Fixed corrupted terrain in several places and rebuilt the affected landscapes.
Crashes and Stability​
  • A substantial number of crash fixes, covering enemy spawning, audio, attribute changes, interface loading, save loading and shutdown.
  • Removed some settings that were implicated in graphics driver crashes, and added a crash diagnostics option.
  • Crash reports now carry considerably more context, which makes the crashes that remain much easier for us to locate.
  • Improved handling of Steam ownership checks, and updated to the current Steamworks release for better Steam Deck detection and controller support.
Options, Platforms and Controls​
  • Increased Geometry Budgets, a new graphics option. Off by default, which uses less video memory; turn it on if you have memory to spare.
  • Frame generation has been reworked. It now applies after a reload rather than conflicting in real time, which the description states, and it no longer switches on before the world has finished loading. NVIDIA frame generation can now be selected on a much wider range of cards.
  • Switch Pro and Switch Pro 2 controllers are supported, with an option to swap their glyphs. Steam Deck and Steam Controller now display the correct buttons.
  • The game now defaults to your monitor's native resolution, and pauses when a system overlay opens.
  • Fixed issue with raytracing options not working as intended
  • Fixed post-process options that had no effect, and firing not working on some controllers.
  • Rumble now triggers correctly for riposte damage, held attacks, Beacon interactions and dungeon transitions, and has had a broad pass across sidearms, items and Shell abilities.
Miscellaneous​
  • Mutton is now immune to damage, he’s been through enough.
Known Issues​
  • Possible Malborn Offspring bug when using Grisha Remnant Summon during boss fight
Thank you for playing, for your feedback, and for being on this journey with us!
- Cold Symmetry & Playstack Teams
Just finished ng+2 right before the update, decided to just rush all the bosses in night mode, no beacon cleansing or dungeons, really only took a few hours. Monolith of course was the biggest pita, I’ve got his number now though.
Both the Monolith and final boss are gimmick bosses with ridiculous individual phases, which I despise. The difficulty for both partially lies with RNG, too. The Monolith can either go ham and keep blasting full-screen lasers that keep it safe...or it can leave itself wide open with an alternate attack. Zmey can either keep doing that one swipe that misses you if you're close...or it can do that instant death tail grab that's nearly too fast to react to. Plus, Zmey even has that stupid final phase that borderline requires you to find a super hidden item. For a game that is otherwise pretty awesome, those 2 bosses can suck a fuck.
Reactions: w35t
how long was your first playthrough?...can you do everything in one playthrough or does it have multiple endings or items that can only be obtained with NG+?
Mine was ~32 hours. That's being extremely thorough, but without looking everything up. I did waste some time trying to fix certain bugs (like a chest that wouldn't open) but no more than an hour or two in total. There's only 1 ending that I'm aware of. Well, there's a second one, but it's similar to the faux ending in Mortal Shell 1.
Thanks to the patch that rolled out today, you can now do everything in one pass if you want. Before you didn't have enough resources to max out all the shells. They added items that let you refund those items today. The only weird thing that you only get one crack at is the tutorial boss. You're supposed to lose to him, but you get an achievement if you take his health all the way down. NG+ doesn't send you all the way back to that fight, so you have to start a new game if you miss that achievement. At least as far as I know. Beyond that, I think you can see and do everything in a single pass if you really want. NG+ doesn't seem any different in terms of difficulty at the moment. That might be due to some buffs/nerfs in the patch, though. With your upgraded gear, it's pretty much a cakewalk.
where does this rank among the Soulslike games you've played?...better than Lies of P?
I'd put it on par with Lies of P. I don't think it's better, but it's no worse. The world maps in Mortal Shell 2 are absolutely top notch, and that's something from Lies of P that wasn't great. It was pretty linear. I was going to say that the weapon/item/shell balance was out of whack, but the new patch might have adjusted that. They even went the route of not nerfing anything and instead (hopefully) just made other items stronger. Ditto with difficulty and annoyances. There were some areas that required PITA runbacks so more save/warp points were patched in. Those 2 final bosses, though. The game makes a hard turn at the end, and like Remnant 2 it's enough to make you actually change your opinion of the rest of the game it's so bad.
As I'm playing through NG+, I'm not actually sure the enemies are any stronger than they were in my first pass. At least if they are, my improved weapons more than counteract that by 2-3X. On the other hand, there's "night mode" which seems to make enemies hit ~50% harder and take ~50% (I'm just guessing here) more damage. It's where the real challenge is. Originally the thought was that it was almost going to be like the lamp from LOTF and make the world totally different, but the differences are pretty minimal. There are only a handful of new enemies and a single new area that's pretty close to the beginning of the game. Maybe as they keep making tweaks they'll add some more night mode exclusive content?
I'm pretty much blowing through the game in NG+ mode without any cares, and I've already discovered 4-5 new dungeons that I didn't find earlier. I cleared the entire first map yesterday. The new update added a half dozen new beacons for fast traveling around. They seem pretty helpful, although I'm a little surprised they didn't add one (or some additional content) near the big ass graveyard area in the NW section of the map. That area still feels pretty sparse, like there's something I'm missing, but I've scoured it from top to bottom.
Oh yeah, the other shells and weapons actually seem to be really good now. Enemies don't just bully through heavy weapons anymore. I'm still partial to Tiel's style of play and the axe/dagger, but I think you can probably use anything and succeed now.
Mine was ~36 hours, up until the last update you'd have to have multiple runs to "upgrade" all the shells as glimpses were fixed, but now they are not, so you can get everything in one run. They also fixed the Berzerker tarstone lockout that affected me, so I have them all now. Once I watch all the shell memories I'll be at 100%. I actually would prefer for there to be items only attainable in ng+ cycles just to add to the incentive, but for now it's mostly just playing with different shells/weapons/playstyles.
On no planet is this as good as LoP imo, but it's still really good.
I'm currently working on a completionist run in NG+3 entirely in night mode using Sariel, will likely shelve it once that's complete.
I just noticed one of the 2 achievements I was missing involved perfect parrying the Nameless Captive's entire spin attack. Wish I knew that earlier. Guess I won't be getting that one any time soon as I'm kinda done with MS2. I'm finishing up NG+ and am just ready to move on. I think it's pretty top notch, but I'm just in need of something else.
Yeah I'm pretty much done with it at this point, I'm just not finding playing with other weapons and shells to be engaging enough to keep things interesting, though I am nearly done with NG+3 (~60 hours total).
For me Tiel was the best, then Genessa, then kind of a tie between Proxima and Eredrim, then Sariel but he was kind of lackluster imo. Lazlo, Gragu, and Smert didn't do a thing for me. Still a damn solid entry and I had a lot of fun with it.
If you wanted to get that final achievement you could speed run to the Nameless Captive, wouldn't take much time at all. This is definitely one of the easier games to 100%.
Well they definitely nerfed the ever loving shit out of monolith, he's a cakewalk now, beat him first try in night mode. Final boss is still a pita though, I threw in the towel after a few tries, I've already beaten him twice in night mode. I'm pretty much done. I'll be all over additional content if we end up getting some though.
I killed the Monolith on the first try via NG+, which was quite the surprise. It mostly just felt like nothing hit particularly hard anymore. I took a few hits, but the stuff that used to boot you out of your shell in 1-shot no longer does. I don't think I even lost my shell at all. Ditto with the hexapod. You can still use Tiel's shadow step to get to his backside and absolutely wreck him while he tries to swing forward. I definitely dropped a few rounds to Zmey, though. That fight sucks on so many levels. It's challenging in a traditional manner, but it's also glitchy as hell, the hitboxes/hurtboxes are inconsistent, and you have to battle the camera to even see what's happening. It's akin Remnant 2's final boss. I wouldn't mind if they just full-on removed Zmey and replaced him with a new final boss. The fight is so messy it doesn't feel like it was even finished.
I found the other weapons/shells to mostly be effective, but Tiel and the Axe/Dagger is still the combo I found best. It's tough to beat going invisible, doing a backstab, and then going ham with like 4X damage from behind. You have to be hands-on and close to enemies, but it really is pretty OP'd. Especially since you get the invisibility back in 2 quick swings and you can repeat the process endlessly. Even in Night Mode.
Reactions: w35t
