Budget allows for either, I like the modular and huge fan they both have. Neither one has a complete set of features, so I have to choose which one is more future-ready:
ModStream 520W
Not ATX12V v2.x compatible
Only 28A for the single 12V, to the Antec's 33A/split
NeoPower 480W
No -5V rail
Doesn't this one only have a three year warranty to OCZ's semi-standard five?
The rig is a high-draw A64/754 (2.8GHz, VCore ~1.7V) running an above-spec 6800, and using a DDR Booster to power some BH-5. The -5V rail is not required for the DDR Booster, but feeds the LCD for direct display of the RAM's voltage.
*I already did a search, all of the similar threads are based on wattage, reliability, etc. I'm thinking along the lines of which is a higher priority: convenience of Booster's display, or future-readiness with split 12V line. I've also read that the NeoPower's 12V is consistently on the low side- should this be a cause of concern?
ModStream 520W
NeoPower 480W
No -5V rail
