I want best performance + overclocking abilities.
I wanna spend >$100 on mobo
Don't get a 965 based board. A Gigabyte P35C-DS3R is not that much more, and it allows you official 1333Mhz FSB support / 45nm support.
There are two different P35C-DS3R mobo listed on newegg.
Think you could tell me which one do you recommend?
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128048
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128050
Both are P35C-DS3R
I would go for the P5K deluxe. I love mine.
Nope, one is a P35-DS3R, one is a P35C-DS3R.
