Mobo Decision
F1a^_^
I'm probably going to go w/ a P35 since I won't be needing a 650i/650i since I won't be running SLI. But when I looked at all the reviews for the P35s, they were all bad for some reason. All of them had some sort of problem. Btw, I read all the reviews on new egg, and each of them had a handful. But...I did come across one. It only has one review, so I know it doesn't mean much. It's at a good price too.
Here it is: http://www.newegg.com/Product/Product.aspx?Item=N82E16813186119 What you think?
I really don't want to spend over $130-$150 for a mobo. Cheaper the better. If you guys find any other boards, or know of any that are 5/5 and are very good and won't give me any problems, please share. Bring on the 650i and 680i's if they are in my price range.
Much help is appreciated because choosing a mobo is the hardest part for me so far in building my new rig :(
Thanks.
[H] just did a ton of reviews on mobo's i'd maybe take a look at the front page, and read them.
I do understand you have established a budget, but i think it the long run it will make more sense to buy a quality mobo to start.
I did read everything. But when I read the reviews on Newegg, they just don't make sense to what people say on the forums. A lot of people here say it's great, had no problems, lalala. But on newegg, there are many reviews, and they really go into detail about the problems. That's why I can't choose. So it would help if you guys could give me some names to start with...
a lot of the reviews on newgg are by people who are obviously clueless/noobs or have their own personal agenda - heck, a lot of them don't even have the board that they are leaving a review for ....
Another board looking at is abit's IP35-E which you can get for under $100 if you look around.
It doesn't have RAID or firewire & it currently has a 2-step boot behaviour (although abit are supposedly looking at curing that) but other than that small glitch it seems fine.
If you need RAID/Firewire the IP35 should be under $150.
The P35 is not the top of the line chipset in the upcoming intel motherboard line, the X38 will eclipse it in several ways. For my own use, I find paying over $200 for P35 motherboards when the X38 will be bringing so many new features to the table in about two months time questionable.
Of course you can argue that there's always something better on the horizon, but X38 should rule the roost for a while. In the meanwhile you probably still need a mobo, so I recommend something that overclocks well without breaking the bank.
Ahh friend a bit of advice, as mentioned above the reviews on Newegg are by perfectly nice people that do not have (99% of the time, there are a few good ones) the foggiest idea what they are talking about. The ONLY thing I ever take away from those reviews is that sometimes I wish to know if some particular memory stick will work ok in a board or if some video card will work ok in some board, in other words I only look at the ones where by luck or intervention of the Gods the poor smuck got stuff working and then only for hardware compatibiliy confirmation. A prime example is the review shown for the board you are considering.
Foxconn IS the leading Edge in MotherBoard Technology
Crossfire is better than SLI
Well if you have ATI video cards you bet your ass it is LOL>
If you have Nivida cards, not so much, jeez what a "person of low illumination".
After I picked myself up off of the floor (if the person had said Manufacturing, he would have probally been very correct) I had a look at that board. Foxconn is making the boards for a lot of companies and is very good at it. But they are more of a contract manufacturer than designer and tend to use reference designs passed to them by Intel or Nvidia or make boards for "Other" big names in computing. I am sure they have their own design guys but they are not "leading" in anything we care about ;)
That board you are considering would probally be fine, well made, standard design not a thing I can say bad about it. My only concern would be user support if you did run into a problem, how many other people have you seen with a Foxconn board in their sig ? Do they have a website with some tech help available ? (if so, great !) Go to the manuf web site and DL the manual and look for thing (usually as notes in the manual) that might bite you and check out the warranty and the repair procedures policies. If all that is good , go for it.
I did notice that this board has no raid feature at all, ICH9 and no secondary SATA controller to provide even basic raid 0. This is not a feature a lot of "standard" people use anyway but I wanted to point it out.
For $100ish after rebate, if you do not have to mail it back to china after the Newegg return peroid expires , its a heck of a deal. You will not find an X38 anywhere near that price.
I am going to dl the manual and have a look at the bios settings and what is availible if you want to hold a few minutes on pulling the trigger. Its a very interesting board, I need a new board for my sons gaming rig, and this appears to be a very good deal for a basic no frills board but still high quality.
Actually not bad, their web site is new apparently, I could not get warranty info page to load, they offer no "out of warranty repair" something that bothers me as I keep MB a long time. They do have a forum for their products a definite + I wish Gigabyte did. But it does appear its all user to user support. Only 3 posts on this board with minor issues, mainly the user did not understand how EIST works and messes with CPU mulitplier. Several bios updates, that good, they seem to be issuing bios updates and fixes in a timely manner.
Here is what I didn't like.
For example, the BIOS doesn't support a CPU FSB to DRAM clock ratio of 1:1,
for hardcore OCing that is a problem, it may have been addressed in a newer bios update but I would be sure to find out. you could just go with 1066 speed memory but that stuff is pricey when another board could use 800MHz memory at 1:1 and OC more.
It also did not do well of max FSB in the review. 387 max FSB is OK with a multi of 9 or more but if your CPU has a max multi of 8 or less your OC will be low.
I make a big deal in a lot of posts that the sweet spot for c2d OCing is 400FSB x 8 multi with 800MHz memory running 1:1 for a CPU speed of 3.2GHz and memory running 800MHz right on spec. and there normally being enough room to get to 3.4 with small increases in FSB from that base configuration.
I am not sure this board can do that. If you are not looking for a big OC it might not matter, but I think I am going with the Gigabyte http://www.newegg.com/Product/Product.aspx?Item=N82E16813128050
$30 more but its a known good OCer and the $30 I can easily save by being able to fully use 800MHz ram instead of needed 1066 for a high overclock and it has RAID which may or may not matter, but mainly I know this board will do 400MHz FSB and has a 1:1 memory ratio available. Critical "must haves" for maximum C2D or Quad overclocking. (as well as CPU and memory voltage adjustments that seem to be on both boards. )
So if you intend to overclock over 3GHz on that Foxconn, I would make absolutely sure about the memory divider and do some math with your intended CPU and its multipliers and your memory and that boards memory multipliers to see what you can do with an FSB that will probally top out at 390FSB max.
Uh...I didn't understand much there. English please :p Sorry, I'm pretty new to this stuff and I don't get much of the lingo you're using. What is RAID and firewire? What's FSB? What's BIOS? I didn't understand anything in the yellow. If you could elaborate in easier terms, it would help a lot ;) Oh btw, that gigabyte board looks great. I don't mind spending $130 on it. I'll spend the money if it's quality.
FSB- Front Side Bus, an interface from the cpu to the rest of the motherboard, it is tied to CPU speed so raising this will raise CPU speed (OCing
BIOS- Basic Input Output System, This starts system and then hands off control to the OS
RAID- Redundent array of inexpensive disks, you can put 2 HDD to copy one another( RAID 1) or write half to one and half to the other (RAID 0)
Firewire- It is like USB and is used for DV cameras.
I agree with you about the ICH9R. You should just pay the $10 and get intel's shiny new SB.
I can't imagine the ICH9 itself is all that bad. I just prefer the "R" version because 4 SATA ports isn't enough for me ;).
I do have a local frys. That Abit board is another mobo I would put on my list ;)
But, what are the advantages of having RAID and Firewire? It seems like everyone just HAS TO have it.
Either way, I'm most likely going to go w/ the Gigabyte P35-DSR3.
Edit: No all of a sudden I saw a bunch of other mobos in the P35 line that I've never seen before...0ops, may have gone to fast and skipped it.
So from this page, which one is best? Disregard price, it doesn't matter. http://www.newegg.com/Product/Produ...4+1070509908+4017+1071828999&name=Intel+ICH9R
Well, while you might not use the RAID part of it, the ICH9R controls more SATA ports which could help you if you're running a lot of HDD's or SATA opticals. The Firewire is useful if you have a video camera or something like that as they tend to be firewire based. Some external HDD's are Firewire based as it is a little faster than USB 2.0, and the first couple batches of Ipods were Firewire based, but I think they also ship USB cables also now.
DS3P doesn't have firewire either.
Now I have nothing against the Gigabytes (after abit they're probably my next favourite mobo mfr) so it comes down to whether the extra SATA ports & the RAID ability are worth the extra $40 ($95 in Fry's v $137 shipped from Newegg) to the OP.
Of course maybe the Gigabyte is cheaper elsewhere too?
I agree. For $95, that's a great deal. If you don't have a Fry's close, $120 is a little steep online compared to the Gigabyte. The budget Abit board (IB9) that I have works well. Seems to be in the same category as that one.
Now I'm confused. There are a couple of Gigabyte DSR3's, and they seem to be the exact same. But they all rang from $120-$150. What's the difference? Would you go Abit or Gigabyte? Btw, I do have a Frys I could drive to and pick up the Abit P35 for $95..if it really is $95.
EDIT: From the mobos that range from $120-$150, do they all OC the same? Or do some OC better than others, if so which ones?
