mITX build Help
XvMMvX
Recently got my nCase M1 in and time to choose the components.
Games I play:
Dota 2
SC II
Hearthstone
Heroes of the Storm
Diablo 3
With this build I am looking for good value for what I do. So if you have a suggestion that is a little more money and better value let me hear it. No real budget here just want to get good value for what I do.
CPU: Already have a i5-35XXK (can't remember exactly but it is an ivy bridge)
Mobo: Already have a Gigabyte PBH61-1 Rev 2.0
Ram: 16GB (2x8) Kingston HyperX fury http://www.amazon.com/Kingston-Hype...qid=1420997573&sr=8-9&keywords=16GB+DDR3+1600
SSD: Crucial M100 256GBhttp://www.amazon.com/Crucial-MX100...TF8&qid=1420997624&sr=8-1&keywords=m100+256GB
PSU: Silverstone SFX 450 http://www.amazon.com/Silverstone-T...=UTF8&qid=1420997674&sr=8-1&keywords=SFX+450W
GPU is where I need the most advice on value:
Geforce 750 ti: http://www.amazon.com/Gigabyte-GDDR...?ie=UTF8&qid=1420997816&sr=8-5&keywords=750ti
Heard this card was poor value if you didn't need a power connect, this particular one has one.
OR
MSI 270X: http://www.amazon.com/MSI-R9-270X-D...1?ie=UTF8&qid=1420997863&sr=8-1&keywords=270X
Most of the 270X are $30 more than the 750 ti, is there $30 worth of value in that upgrade? Lastly the only other card I have considered is a used 760 but then I would give up mantle.
Look forward to your replies.
Even if the 750TI had a power cable, it's still not a good choice from a price to performance standpoint. Yes there is $30 worth of performance increases over the 750Ti with the 270X. However, at $185, that R9 270X is ridiculously overpriced considering that $15 more gets you significantly faster R9 280:
http://www.newegg.com/Product/Product.aspx?Item=N82E16814127789
From a bang for the buck standpoint, the above MSI R9 280 card is your best bet. But if you want to save money, go with this cheaper $160 R9 270 card:
http://www.amazon.com/dp/B00GMGGZQE/?tag=extension-kb-20
Before you ask, yes there's $40 worth of performance increase with the R9 280 over the R9 270. But the $160 R9 270 is still an excellent choice for the money.
Maybe wait for the Nvidia 960, it will probably be more expensive. But it will hold you for longer.
Dangman, thanks for the suggestion. Based on your info I got the R9 270 for $160.
I considered this but I will rarely "wait" for technology. Especially for something I don't need. The 960 doesn't even have an official launch date and then it will probably be a bitch to get and be overpriced.
So I just pulled the trigger.
I'll post pics of the build this weekend hopefully.
:D:D:D
Dangman thanks for saving me a few bucks on the video card. I got the system together and my games run perfectly.
