Mini/Micro ATX Cube Case for NAS
ldoodle
Hi,
Currently have a huge tower and want to downsize. Does anything exist that is more like a bought NAS in that its a cube/rectangle?
Really rather DIY so looking for something that has 6 5.25" drive bays for 4-in-3 hot swap cages, but need them side by side rather than upwards.
I have space for 24cm high, 40ish cm deep and 40cm wide.
Thanks!
The only other chassis style that I can think of that has 6X 5.2in bays are server cases.
Doesn't have the 6 x 5.25" drive bays, but it does have 8 hot swappable trays. It looks like it could be laid on it's side(non hinge side) and it would fit your dimensions.
Silverstone DS380B
I had a unas case the 4x bay itx model and was able to cram a z270 mobo with an i5, there are severe clearance issues for the heatsink in that chassis, but i believe the 8 bay ones have way more room. Very quality enclosure. I want to try a silverstone but look up the cardboard mod for airflow.
