Mini-ITX till sandy-bridge comes out...
a few games, Music, Photoshop, Dream Weaver and Bridge
~$600 but it's fudgable...
3) Where do you live?
West Chester, Pa
everything from the PSU to the screws that hold the case together
none
6) Will you be overclocking?
doubt it
30"
within the next two months
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? etc.
-Small... preferably Mini-ITX
-Dual Ethernet
-USB3 is a mugo plus
-SATA3 is a must
I'll use Windows 7 x64 till I'm satisfied with sandybridge... then when I upgrade I'll switch to Ubuntu Server...
I' kind of like the idea of the ASUS M4A88T-I Deluxe AM3 with a phenom2 x4/x6... kind of a shame it only has 3 SATA ports and they're only SATA2...
any ideas?
-Ian
Do you happen to have a spare PC that'll need a GPU upgrade after you ditch the mITX build for a Sandy Bridge setup?
As it stands now, you're not getting a mITX setup due to your second and fourth requirements: No mITX motherboard I know of has SATA 6.0Gb/s. Nor does any CPU replaceable and consumer grade mITX motherboards have dual LAN ports. You're basically looking at a mATX build.
Is there a reason it needs to be this small? Doesn't look like a HTPC build and the small parts cost a pretty penny more.
Yeah, the m4a88t-i was close, but ASUS went back onto the SB750 due to a few factors:
Massive package sizes of the NB and SB chips.
No native core unlocking in the SB850 (like the 95W TDP recommendation could do a thing about it)
Core unlocking with SB850 requires yet another chip to work - not enough space on MITX board
Basically, because of core unlocking, ASUS chose an older chipset... SB750/SB850 are pin compatible, and the NB is already the newer 880g...
iirc, Sandy Bridge will have SATA3?
Danny Bui is correct on the Dual Lan. Other than a junk J&W board from a while ago, none had dual Ethernet on mITX (consumer, I know MSI and ASUS also make industrial mITX/DTX boards which possibly might have it).
@Danny Bui: what do you mean by "Do you happen to have a spare PC that'll need a GPU upgrade after you ditch the mITX build for a Sandy Bridge setup"?
And I guess it doesn't actually need to be small... I guess I just need a half decent AMD server I can temporary use as a main computer till SandyBridge comes out... I guess I just got caught up in the whole little computer the size of a hard drive idea :p
Any recommendations there? I've never used AMD to build a server... just one or two work stations...
I feel like I'm spamming your forum with new build threads... :(
Thanks,
-Ian
what I *think* he means is:
do you have another setup you can spend little money to update to your current needs, then wait until Jan 2011 for what you want?
Snady Bridge (LGA1155) is launching around that time, mITX glory and all.
If its just a temporary PC you could probably find a mid level system on the for sale forum here then resell it after you do your sandy bridge for not much of a loss.
Is there any way you can narrow down when you're gonna build this server? I mean since Sandy Bridge is about a month and a half away, it just seems odd that you're planning on doing a server build two months from now, a half month after the release of the Sandy Bridge CPUs. I mean, if you said right now you're gonna be building a server, as in before the end of the month, we can easily come up with a decent build.
Nah, you're not that bad. There was this one poster a year or two back who would make a new thread every week with the same PC build with a slight modification here and there and asking again and again if the parts were good choices. Jesus christ was he so bloody neurotic about the PC.
Actually I was thinking more along the lines of you forgetting about the SATA 6.0Gb/s requirement and getting that AMD mITX setup with a dedicated GPU for gaming. I'm assuming that you won't be using the second NIC until that mITX becomes your server after you switch to Sandy Bridge. AS such, you just remove the GPU, install a PCI-E Intel NIC and theres your server.
:) glad to hear there are more annoying people out there than myself!
my main issue is that my current rig is a pentium4 (w/ hyper threading mind you) running around 2.6ghz on a proprietary ASUS board built for Sony's VAIO line... there's an geforce 7800 GS (the AGP version) and a gig of RAM... I really don't want to dump any more money into this old lady...
but whoever said that "[I have] waited this long already, I can wait a bit longer" was right... it's just painful :( but I guess I could go buy some new glass for my SD14 :D :cool:
