Thanks for checking out my worklog. Latest updates are marked by big bold red headers. Can't miss'em.
Intro:
I wanted to make a small mini ITX system dedicated to Steam and emulation. The more compact the better. The end goal being a clean console-like build with a clean front end. Easy to just fire up and play a game or two.
System Specs:
- i3 3220
- ASRock H67M-ITX
- Samsung 840 250GB SSD
- Kingston HyperX 120GB SSD
- HyperX 4GB DDR3
- 160XT-picoPSU w/ 192W brick
- HD7750 1GB low profile
- X360 Wireless Controllers (x4) + internal receiver
I have my own CNC machine. However, many of you know that it (specifically the electrical side of it) has caused me absolute nightmares over the past months. Therefore, I am borrowing a co-workers NC system to tie up some loose ends.
Materials:
This case is made entirely from scrap pieces left over from the m3a2 project. I didn't want to eat into virgin aluminum stock (untouched, not machined pieces). Spare/existing parts only.
Design:
A lot of you have seen this before. Pretty simple design. It accommodates only the essentials when it comes to hardware.
Dimensions: 90mm (W) x 207mm (H) x 198mm (D)
Volume: 3.7 liters (0.97 gal.)
Construction is 100% aluminum. Specifically, it is machined from 6063 and 6061 aluminum extrusions and plate. Side panels are 3mm thick, top/front/rear are 4mm thick and the bottom is 8mm thick.
Machining Bottom Piece:
The actual bottom panel differs from the 3D models above because I wanted to use a scrap piece. The scrap piece was actually twice as thick as the other panels, which allowed me to machine feet into it, creating a air gap for the GPU to draw in air. I clamped the piece into a make-shift fixture to hold it straight and hit [cycle start].
VIDEO
Note: Not shown is a the rear panel being redesigned and recut to fix a mistake in the design.
Heat Build Up:
I was hoping that my low power system I built inside would not generate a lot of heat and that a chassis fan would not be required (to keep things quiet). However, even with a little 35W i3 2100T and HD6670, the heat would build up, little by little. Nothing crazy, but enough to make the fans start to wind up with HD videos or mild gaming. More air flow was required. A 140mm fan fits just right. Now to machine a vent into the side panel.
Another Look Around the Unfinished Case:
The case is nearly complete. Even though I do kind of like the natural brushed look of aluminum, It will be powder coated in a textured black. It will also be getting a black power button with green LED ring.
Wiring Modifications and Cable Management:
Coming soon...
Xbox360 Wireless Controller Receiver and Wifi:
I want the Xbox 360 wireless controller receiver mounted internally. Also, my motherboard does not have build in wifi. I wanted wifi capability without having another USB dongle off the back. Plus, I had this wireless adapter to use and it fits the application.
Basically all I did was desolder the connectors for both the x360 receiver and the wifi adapter and soldered on a shielded USB cable with onboard-type USB plugs. I also ran a momentary switch off the X360 receiver to sync controllers without having to open the case. Pretty simple. I'll finish them up with a tab of hot glue to secure the leads and shrink tubing to prevent shorts.
The wifi adapter will be secure to the back of the case by the antenna and the x360 receiver will be secured to the SSD bracket at the front.
BEFORE
AFTER
LATEST UPDATE: July 23rd, 2013
Final Assembly and Configuration:
Did a fresh install of Win7 and got the bugs worked out on the base system (no games/emulators). Flashed the BIOS to 2.10 and put in the new SSD. Modified wifi adapter works well after finding better drivers.
Note: Stock Intel cooler shown below was only mounted with the G530 to flash BIOS. System is currently running the Noctua.
Issues:
Other notes:
- The range on the Xbox360 RF module was severely reduced when inside the case. Regardless of location inside the case, range was limited to 8 feet max. Okay for desktop gaming, but not for use in the living room.
- Closing out of emulators with nothing but the x360 controller requires Xpadder to do an Alt+F4. Problem is that F4 also has a function in some emulators and games, causing strange problems. Example, Project64 has F4 mapped to something for fast forward or something like it.
- I'm currently booting straight into Steam Big Picture, doing a simple Shell regedit. Works very smoothly and I haven't had any issues with thus far.
- The computer stays pretty cool. It helps that most emulation is CPU. The i3 3220 is cool running in the first place, but is also really well cooled in this case design. During PC games (not emulators) the HD 7750 does get a little warm, like around 64*C, but this well within acceptable temperature range of just about any card.
- Xpadder is an excellent application for emulating keyboard on a controller. Makes certain things a lot easier for complete game pad operation.
