Every time I see this post I start looking on FB for an old vintage radio for my next itx build lol
What a crazy small speaker for it's time. I think it nicely matches your radio. Would be cool to run a random aux speaker in there and you could just switch it on the fly in windows for neato factor.Small teaser
Looking at getting this old external speaker.
Measurements are ok to fit a radiator in there, and perhaps also an extra pump head.
Then some new hessian fabric to match the speaker and some oil etc for the wood.
Could be nice?
No change of 2x 240 rads sadly, but could go 240x45 and then do push pull if needed.Do it. any chance of stacking 2 240 rads? Or doing one rad and adding a bigger gpu(with a long AF riser cable?)
Wait. I need to go through the thread again but what RX6600 do you have and where on earth did you find a water block for it?RX6600.
If you want I can do some measurements when I get the card out?Wait. I need to go through the thread again but what RX6600 do you have and where on earth did you find a water block for it?
Edit I went through the thread. Been looking for waterblock instructions for my XFX 6600 because I wanted to know thermal pad thickness(Id like to paint my fan shroud and with the 6600s being a 'budget' card no one seems to make them. Bykski makes one for a different brand. I wonder if the thickness would be the same
I haven't taken it apart. worried about damaging existing thermal pads with no reference to get replacements. I may reach out to XFX and see if they will spill the beans on that it not.If you want I can do some measurements when I get the card out?
Have you tried to remove your heat sink and see the PCB layout for the xfx rx 6600? Maybe it will fit.
Well yes but that would require taking the card apart first. I don't want to take it apart, damage a thermal pad and then wait for shipping. I would rather have the thermal pads on handcant you just measure the edge of one?
Taking the card apart won't render the pads useless if you're careful. I have never had to replace the stock thermal pads after pulling the heatsink. And I've pulled more heatsinks than I can remember.Well yes but that would require taking the card apart first. I don't want to take it apart, damage a thermal pad and then wait for shipping. I would rather have the thermal pads on hand
I was just going to tag you in that thread on the forums and see you beat me to it. I haven't used them, but all of the replies in the thread as positive.Just got my hands on a second hand 5800x and a Asus 3060 TI mini dual V2.
I need a waterblock and I saw that this German company sells a nice looking block for the GPU:
https://www.liquidextasy.de/gpu-wasserkuehler/nvidia/rtx-30xx-series/wasserkühler-narrow-asus-rtx-3060-ti-dual-8g-mini-detail.html
Anybody have any experience with them, looks really nice and easier for me with a German company since I live in Denmark.
I think the current form factor and temps are super cool. No reason to get carried away with loop temps if it's already more then sufficiant.Ok I'm a little less worries now
I guess I could add another rad to see if I can decrease the exhaust temp compared to ambient and perhaps run with a little less fan speed?
Yeah, my massive water cooling setup lets my 3090 run at 45 or so.50c is pretty good and inline with decent water cooling setups.
You could also jank it and throw a rubber square between it and the housing.So it seems that the noise comes from my angled fitting that goes to the top of the reservoir.
It is touching the wall slightly, so I'm thinking that I could tap and drill a hole in the top cap of the reservoir and move the fitting to there instead.
Yeah I ended up drilling and tapping the cap:You could also jank it and throw a rubber square between it and the housing.
