Top Secret!
ill spawn on you then
Top Secret!
What are you guys using for texture packs? I was using Brown & Bloom, but it's really screwed up in 1.22.
current map size is 48618 x 20474 and is over 100MBs in size
If there were some way to keep the sun out longer I'd do it...
I haven't seen or heard of anyway to do that tho.
I'm on my phone...about to try loading the picture
Got about 1/3 done, lost 3% battery life and errored out. Guess I'll wait til I get on a computer.
I have to find a program I can use to crop the image down in sections or something... I wouldn't know how to host this lol
Use drop box and put it in the public folder.
Right click the image>Dropbox>copy public link
Post teh copied link here. once the File uploads to Dropbox, we can all dl it, with no effect on your server. Plus, updating it is easy. Just save a new image with the same name.
Cept DropBox public files like that go overlimit real quick.
You are better off using megaupload or something like that.
Yup, same for me. I think that setup is just about perfect and I wouldn't go any higher res. I haven't seen any texture packs over 64x64 that look "right" in Minecraft.
A4rrows, where is Explo1on the map?
Set graphics to "FAST" instead of "FANCY"
I shouldn't have to do that though. I don't know how a 6870 and a quad core can't run this thing over 200fps.
Tried to join Sul's server, keep getting this result "Connection refused: connect." Can I not join MP if I have mods installed or is that something else?
