Dxtory. Download it, install it, run it, go to advance tab, enable FPS limiter to 30, never lag / stutter again as long as the framerate never dips below this. Its a frame cap limiter. Eliminates any frame rate anamolies, even multi-gpu microstuttet. Works in any game / benchmark. you can set your fps higher if you need a faster more precise gameplay, As long as the fps doesnt dip below this setting. Never be bound by gpu drivers again.
