Micro ATX in ATX case?
rpeters83
Sorry for the newbie question, but is it true that I can put any micro atx mobo in an atx case? I plan on removing the board and cpu from my old hp pavilion 542x (which i'm pretty sure is atx) and put in a new mobo/cpu combo.
will this work? i don't mind the fewer expansion slots - it's a server anyway. thanks.
The answer is yes. Most cases nowadays do support mATX motherboards.
so, even if the HP case originally held an ATX board it should support a micro atx? thanks,
even this old as stock case from circa 2001?
if you say so, i'll order it...
You might need a more modern power supply though to power a newer board if your case is really that old.
But to put it in perspective, I'm running my current system in my sig in an old Gateway Pentium 1 166mhz case :). Airflow sucks, but other than that, it has plenty of room and is definitely a sleeper case :cool:.
thanks. i think it's like a 200 or 250 watt psu, which is fine as a server.
Not really. If it came with the PC, then its more than likely a low amperage PSU of low quality. In other words, if it says 200W to 250W, it could be a 150W or even 100W PSU
Not to mention that it probably won't have a 20+4pin ATX connector which pretty much every motherboard now-a-days uses.
