Bill, notice I focused ONLY on motors... Not on actual E&M. "The idea that your pump will mess up your disks at all is a complete fallacy." I didn't say that magnetic fields couldn't mess up your disks.
On another note, do HDD's have faraday cages in them? I don't see one through the window of my WD RaptorX. Or is the steel casing just enough to act as one?
if the plater is electrically isolated from the disk housing then the housing can act as a Faraday cage..... however this only remains the case so long as the magnet is not brought into contact with the disk housing.....as was pointed out earlier putting a horseshoe magnet onto the drive has a negative effect.... well.. lets consider two things... 1. the lid of the hd is made of steel which happens to be a magnetic material.....2. point focus of the magnetic field.. which makes the field more directed....... as for the magnets inside the drive you will notice they tend to always be oriented in a specific way, there is a reason for this.....
ok now can we please get back to talking about diamond thermal interfaces again......
