bonkrowave said:I think these pictures, be it real or not, show the XBOX 360 to have a very aesthetically pleasing design. As a registered Industrial Designer, I can say that many styling cues are taken from trends currently found in electronic devices, such as laptops, receivers, etc.. The trend in the product design industry is all about minimalism. The design is in line with the design methodology of the XBOX 1 with the hard straight lines, but has its own unique design, through the use of subtle curves, arcs, and radii.
Its not a mistake that the XBOX 360 looks similar to Apple designs, for the simple fact that apple products have been winning industrial design awards for years now. I would think it ignorant to knock the design when it has design cues taken from award winning products. Its clear that this design will use injection molded parts, and a half shell approach. The fact that is symmetrical down the horizontal midline would suggest, it was designed this way so one mould is needed for the top and bottom section as opposed to two. This cuts down on cost dramatically as injection molds are very expensive to produce.
Design is often influenced through the manufacturing techniques, which are used to create the design. A unit such as the XBOX 360 is not going to be full of undercuts, complex lofts and curves, simply for the fact that mass manufacturing products with these type of features will increase the cost of the product.
Just because there are cases, for PC, with samurai or robot faces on them, does not mean these are "good design", and should definitely not be looked at, for design inspiration.
I appreciate good design, but it's a fine line between minimalist and bland, I don't particularly like this design, but then I don't recall ever finding any console aesthetically pleasing.
