- Apr 26, 2009
Here's mine: Leopold Otaku w/ Red Switches and Ragnarok Caps
Thinking of buying a Leopold when I get to the US, but the ANSI layout and Cherry stabilizers worry me.
I own a few Filcos and a Das, trying to sell them off, actually.
How much did those run ya?
I'm not even sure you can get any mechanical keyboard for under $60 except maybe a tenkeyless model on discount...
The TKL models seem to be as much or even more expensive than their full size variants, in my experience. That's good for me because I do like having a numpad, but I can see the appeal in a TKL board (saving space; having the mouse closer to the kb).
I have to say I'm extremely surprised that Logitech hasn't joined the fray to try to cash in on the mechanical keyboard craze. I wonder if they have something in the works, or if they'll stick with rubber dome keyboards forever. Seems like they could do very well if they introduced a mechanical board; lots of people look to Logitech for input devices but then again they'd probably make it too "l33t g4m3r-ish" for me. Still, their customer service is hard to beat...
I'd get a logitech if they made mechanical keyboards. I just had a good experience with a corsair RMA and remembered I had a $50 newegg gift certificate.
Anyone find issue with this keyboard: http://www.newegg.com/Product/Product.aspx?Item=N82E16823816001
How do black and red switches feel compared to the typical rubber dome keys in regards to pressure needed to push down?
It depends on the rubber dome as there are a few that are pretty good, but typically i think rubberdomes are somewhere 65-80g of activation force for each key while blacks are 60g and reds at 40g. So to answer your question, both should be less pressure.
Is that the pressure to activate the mechanical keys or to bottom out?
What is the key travel comparison between the mechanical keys and the rubber dome keys?
Activate, and are you talking about in terms of distance or tactile feedback?
Just distance. I will be gaming on it mostly and bottoming out for movement and such will probably be common. Wondering how much adjustments I will have to make going from rubber dome to mechanical.
Mechanical switches tend to have longer key travels from what i recall. It'll take a few days for you to adjust to using a mechanical keyboard, some people add o-rings to the keycaps/switches to shorten the distance and if you get a really high flex one it would give you a bit of a mushy feel which you may like coming from rubberdomes.
Does anyone know when the last time the first post has been updated?
I've heard browns don't have much of a tactile feel, but I've also heard it grows on you after a week or so. Because if you're used to membrane keys you're pressing harder than you need to.
I have blues and reds right now, with browns coming in today or tomorrow so I'll be able to tell. I have a feeling I would prefer clear switches which are browns with a stiffer spring so it feels more tactile like blues.
If someone (like myself) is motivated by the expectation drastically different and noticeable tactile experience from a membrane keyboard, browns will not be satisfactory. I'd recommend blues over browns for someone like that.
Switches: I got the Browns (with "tactile bump") to be a compromise between the Blues (with "tactile click") with the responsiveness of the Reds to fast-tapping. However, the "tactile bump" of the Browns is so subtle as to be entirely unnoticeable unless you deliberately press them down very slowly to feel the soft bump. I got the Browns because I read that the Blues had a difference in actuation point versus clicking point that makes double tapping an issue at extremely high speeds and that the Browns were a good compromise.
