- Jun 18, 2009
I wash my hands all the time. The fingernail thing is possible but unlikely, since my fingernails are usually this length:
...just a thought, it could be a detergent in the soap you use or possibly an additive in a lotion? (I'm assuming you use lotion since you said you have dry hands.)
I still always wonder if the price is truly justified.
My current Logitech keyboard has lasted me 6 years, and huge doses of punishment.
Something clearly causes some people to wipe this stuff off very easily.
To wear a letter off you should have to wear through the clearcoat and then wear the letter print down. That means you should see degradation of the clear coating (like bad clear coat on a car) before the letter rubs off.
...the soaps/lotions/moisturizers are a possible reason, but I do change those relatively frequently.
I just got my BWU today. It's a wonderful kb to type on. Feels so much like quality! And yes, it is bright enough but even unlit, I can see the keys just fine during the daylight but I like the blue, so I leave the led's on.
Great keyboard!
I use Dove white with moisturizing cream soap to wash with and I use stuff like this: http://www.nextag.com/Vaseline-Inte...prices-html?nxtg=3810a280503-6C433826D67C7329
for dry skin in the winter time. My hands can get dry enough in the winter if I'm not careful that I'll start getting splits.
When I use any of that I make sure it's soaked into the skin and any "excess" is wiped off before touching anything including the KBM so if that's what it comes down to for my Rosewill's fading situation that's going to be a shame. And kind of silly.
I wish there was some place I could just go and try out one of these mechanical keyboard or even just be able to test the difference between mine and a mechanical one when gaming.
This may sound stupid... but I can't live without a calculator button.
Do you mean a button that launches the calculator or the numpad?
Do you have any computer stores where you are? I went to one and they had the Steelseries and Razer mechanical keyboards. I asked to open the box to try them out and they said no problem.
Okay, does anybody have any recommendations for palm/wrist rests? I am finding the Razer BWU to be uncomfortable to use. I came from a virtually flat on the desk Apple aluminum keyboard. My fingers have to be raised quite a bit to type properly on the Razer keyboard.
Everyone has some natural oils on their skin, some peoples' are just slightly more corrosive. At least that's what someone told me because half my old keyboards have the printing worn off on them![]()
The only one outside of really tiny computer shops is Best Buy. I live in PA, so no Micro Center here. And yes, a button that launches the calculator. I know I could program one of the other buttons as a shortcut, but I like this one. Mainly because every other time I've tried a calculator button on other keyboards, it only opens one window. Each button press with this one opens a new one. It's very useful.
Zarathustra[H];1036992986 said:Ha, I always found the "accessory buttons" a waste. Never use them.
That being said, I never use the calculator. Whenever I need to calculate something its always directly to excel![]()
Why the hell would you go to Excel to calculate something? The built in calculator is FAR easier to use and faster.I've heard of some weird behavior as far as computer usage goes but that's just crazy.
I just set m3 on my Razer Blackwidow Ultimate to launch calculator and a new calculator opens up everytime I press it. The software is the best I've used for custom mapping keys to other keys, launching programs, macros, etc.
I saw one on Amazon for the normal price (120 USD), and figured what the hell, why not. Well turns out that vendor was out, so a week later I had to cancel the order and place another order from another vendor. Opting for 2 day shipping, I have received my keyboard 2 days later.
Sad part is that I don't have M5 mapped because when I first got the keyboard I would hit M5 instead of ctrl.
Um, why would you go through amazon/vendors? You can buy from the manufacturer directly:
http://www.daskeyboard.com/
I mapped M5 to CTRL
Also, map other keys that you don't use. Why not use the context menu key (between Fn and Ctrl to lock computer) and you can map scroll lock to something else as well.
I've been using my das keyboard for a few months now and I just don't like it
I'm not a touch typist and it seems like I make way more mistakes with this keyboard than my old logitech "soft" key G13
so I'm going back to a logitech, maybe a G510 or G110
on another note, what's my best bet for learning to touch type after 15 years of using my own method of mostly index and middle finger? I can type most stuff without looking - about 90% of this post was without looking at the keyboard but it's just because I know where the keys are in space, I don't have a "feel" for the keyboard
