MBO not working
That new address he sent is probably wrong too and I could send it indefinitely, that's obviously their trick, I would spend another 21 euros for nothing and I would never get my money back
Exactly.
My last experience with Aliexpress refund was similar to yours, that's why I suggested doing chargeback right away, not to waste any time playing their game.
My story was as follows: received item, it was damaged, opened a case in Ali, got weird address from the seller in the country where I live (UK), I inquired the seller several times because postcode was 00000, clearly not right. Got nowhere and sent it anyway (cheap £3 parcel), it was undelivered or some other problem, don't remember exactly, Ali closed my refund case because seller did not receive the item back.
Then I opened a chargeback case with my bank, to reverse the debit card transaction, reason - item received not as described, merchant not cooperating with the refund.
They approved it and I received a full refund. Aliexpress didn't realize it, even after I got money back Ali was still showing that I have not returned the item so I am ineligible for any refund.
I've bought a lot of things and they were mostly all positive experiences until this one, this seems to be the most expensive thing I've bought.
I did a refund once again for a game console (an emulator of old games), it was working and everything but I just didn't want to keep it, I didn't like it. That all went well, I returned it and got my money back.The only thing is that the postage when I send it back is quite expensive and I can't send it cheaper.
AliExpress has issued a refund. Typically, financial institutions should process within
1-10 business days
The time was expired that Aliexpres set up, it seems like it will give me back money. As for the shipment, it still says that it was a delivery attempt 07.03.2025.
Previously, I reported everything to the bank, attached everything I had, but they have not informed me anything yet.
I got my money back, what should I buy now? Asus AMD MBO boards don't have the latest bios where security vulnerabilities are fixed and one of the conditions is that the MBO must not have a pcie slot for the gpu in the first pcie slot.
On this last asrock MBO I could barely fit the hdmi cable into the gpu, the top part of the case gets in the way, I couldn't fit the display port cable in because it's too thick, the stupid case gets in the way, the top part.
What do you think about this MBO? It seems that Asus updates the bios for those old motherboards, the last one is from 04.11.2024.
I like this one, it has 10 phases (mine only has 6) and I would also like a pcie4.0.
It also has a wifi antennas so I wouldn't need a LAN cable, that could improve my connection which is now only about 1mbit max download.Price around 150 euros.
https://www.asus.com/motherboards-c...aming/tuf-gaming-b550m-plus-wifi-ii/techspec/
Howdy fellows, my MBO came back today, what should I do with it now?
It's been many months and I didn't think it would come back, it came in the same box that was quite worn out.
do whatever you were going to do that lead you to buying it in the first place?
It's going to the service center, as far as I can see from the bios, any ryzen from the 3000 series should work if it's an older bios and assuming it's correct. The worst thing is that it has a pcie 16x slot for the gpu in the first slot up high and I have a case that's hard to push a DP cable or hdmi cable into if it's thicker. Hdmi comes in but with resistance and it's not really for holding constantly. You never know until you see in real conditions what's bothering you. Right now, let's say the gpu backplate is bothering me a little. Above it is the pci sound card and that backplate is bothering me even though the gpu is only 2 slots and small in size. I can imagine when you buy a gpu that is over 2.5 slots, an ATX motherboard is required for that. On mATX, it covers all the other slots.
I bought the mbo because it has better voltage regulation and because it has pcie 4.0, it also has the newer realtek 1220, everyone says the old one is no good, the b550m steel legend is much stronger than the b450m steel legend.
So far, no service, no one has a cpu.
the bios update was made, would the ryzen 5700x 3d be a good upgrade for that mbo? the rest of the configuration is rtx 4070 super, 32gb 3600mhz ddr4, the monitor is samsung ur59c, 32" 4k 60Hz
I currently have a ryzen 5600x on an old thermalright venomous x cooler. How much would the gain be in, say, BF6? Would I still have to buy a new cooler, it's hard to cool the ryzen 5700x 3d?
Or would it be better to buy a ryzen 5950x, 5900x or 5900xt since they are all quite similar in price?
250eur-270eur
I don't know why no one is answering.
I researched ddr4 memory and that 5600x, so this memory I have 2x16gb 3600mhz and XMP profile of 18-22-22-22-42 has nothing to do with amd and ryzen 5600x, so my memory can work at 18-20-20-20-40 but the secondary latencies are again high and the gain is zero. And there are still errors calculated and set. When I put it on auto then ryzen puts latencies of 26-25-25-25-58 and that seems ok because then it automatically calculates secondary latencies well. This way with cl 18 it's like faster but you never know when it will break. And I don't know what kind of mbo I should have (probably from 200eur+) for that memory controller to be good. Because according to this my memory controller is not good at all. If I put GDM to OFF then it is completely unstable memory. So it only works with 1T and GDM OFF or 2T and GDM ONN.
These XMP profiles that my memory comes with are Intel profiles, it has nothing to do with AMD. Intel still had a huge influence back then. Maybe that's changing a little now because everyone buys AMD CPUs because they're the best.
I don't understand how people brag on the internet about CL14 latencies and 3600MHz and higher clock speeds for AMD Ryzen 5600x. Obviously the MBO and that memory controller make a big difference.
I don't know what I should change to get maybe better results with secondary latencies. This MBO sets automatically.
What is the actual question?
And the memory controller is on the CPU, not the motherboard.
How to improve secondary latencies? And if the memory controller is on the cpu it means my cpu 5600x is garbage, even though it was bought late and should be better.
They brag about CL14 latencies and the like on the internet, I can't even get CL18
Does the memory even support those latencies or are you just hoping to get it to those timings. Remember, anything over 3200mhz is overclocking so you are not guaranteed anything above that.
tested and supports 18-22-22-22-42 with 1.35V at 3600MHz
I'm not as interested in primary latencies as I am in secondary ones, is there anything that can be changed there?
I have no idea what that kit actually supports. Try looking it up on Patriot's website.
