mATX Phenom AM3 w/ SLI?
I can't seem to find any motherboards that are mATX form, AM3 socket, with SLI support.
I'm going to be using a Phenom X3 720 Black Edition, and NVIDIA GTX275's. (two of them)
Does this not exist?
I really want to place my order for this system yet nobody is replying, does this mean no board exists?
No such board exists. Most of Nvidia's chipsets for AMD CPUs are now concentrating on the HTPC market. There are AMD SLI mobos but they are all ATX mobos but theres only one AMD SLI AM3 mobo out there.
I don't recall there being a nVidia AM3 chipset.
Only nVidia liscensed products can have SLI, while xFire is free to OEM/ODM.
There are no SLI boards I can find with your requirements.
Wait a bit, the new 5xxx series is comming soon (and if you don't like ATi, then it will at least drive the prices down).
EDIT: argh! I'm late in posting again!
there's a 980a which should be am3 / sli. no matx 980a boards though. i don't think there were even any matx 780a...
You'd be hard pressed to find mATX boards with sli or crossfire. There are only a hand full of boards that can run one or the other, and the majority are i7 boards. Most of the mATX boards only have 1 x Pci-e x16 slot.
It's true that there is no mATX AM3+SLI motherboard. But there are quite a few possibilities for mATX multi-GPU boards:
AM3 Crossfire: There is one from DFI
775 Crossfire: 1 DFI and 1 ASUS (Maximus 2 Gene)
1366 Xfire/SLI: Asus Rampage 2 Gene, MSI X58M, EVGA (I might be forgetting one)
1156 Xfire/SLI: Maximus 3 Gene and Gigabyte P55M-UD4 (with more to come, I'm told)
Only problem with these setups is that when you install 2 dual-slot graphics cards there isn't much space for them to 'breathe', which usually means higher temps and/or more noise.
