Nenu
[H]ardened
- Apr 28, 2007
When my too hot today beers wear off I'll give this a go.
Assuming I dont fall asleep first.
Man its hot today.
Man its hot today.
yay to more improved facial animations!...when I finally fire this up the characters might actually look half decent![]()
Not seeing any difference in HDR...so I'm guessing that was for the Dolby HDR standard. Everything still looks extra bright and violet for me.
Getting a bit further into the game and it definitely feels a lot like Dragon Age Inquisition. Lots of fetch and scan quests keep showing up. They're distracting and very grindy. I do like the gameplay, though. The sniper/shotgun combo has been a long time coming. I like the level-up system, too. The R&D stuff is still clunky, though. It feels like either you have to look things up online or just guess.
Played a bit more. Chose to destroy the facility. Was very disappointed to find out that the Kett are just Angara gone bad.
Now I don't know what I have to do but I just shut the game down after escaping from that facility and saving that Moshae whatever.
I think I may be able to stomach the main quest after all.
I think you might need to pay more attention to the dialogs; The Roekar might be Angara gone bad, but the Kett are something different entirely.
Does the game just keep dishing out fetch missions as you complete the existing ones? I'm still on Eos (after moving the plot forward and getting Jaal) and it feels like they just keep creating new fetch missions one after another. DA: Inquisition had a finite number of missions - does Andromeda? I'm finally at the point where I have no plans to do any more, but my list of random fetch quests is a mile long...and most seem to be Eos specific.
I did the regular side quests, but fuck the "find" quests where there are no pointers. pure waste of time to scour the maps, even using a map guide it is still a monumental waste of time.
Yea, but they want to do that to everyone (and apparently did that in their home galaxy).
Ah- fair enough. I thought that it was clear from (almost) the start that they had arrived from another galaxy and were tools.![]()
I think I'm just going to bail on the fetch quests. They just aren't fun and they're a bit of a distraction. So far I don't dislike the game. It's not really any worse than the first game, which was also pretty repetitious. Gunplay is probably they best it has been in the series, although I still hate "auto-cover."
Minor correction: The Kett are from another Andromeda star cluster, not another galaxy. From what we can tell so far, no one has FTL technology any more advanced than what the Initiative brought with them.
This is a departure from the trilogy where the Mass Effect Relays formed a network of clusters and FTL drives themselves were used largely in-cluster. So, the entirety of Andromeda takes place in a single cluster, that happens to have a lot of 'viable' planets due to advanced terraforming technology.
They key is not to let the side quests distract you from the main story. Whenever I can't take another side quest, I progress the main story. That helps.
Thanks. I had this exact problem for my friend. I said how can the Tempest jump between systems yet the Normandy (which is larger) needs Mass Relays to jump around.
The Heleus Cluster is also a magnitude smaller than the Milky Way Galaxy. A satellite galaxy similar to Heleus would measure in the thousands of light years across instead of a major galaxy that would be 100,000+ light years across like Milky Way and Andromeda.Thanks. I had this exact problem for my friend. I said how can the Tempest jump between systems yet the Normandy (which is larger) needs Mass Relays to jump around.
The 10 hour trial is back and the game is also on sale. I'll give it a whirl.
http://www.pcgamer.com/the-10-hour-mass-effect-andromeda-trial-is-now-available-to-everyone/
doesn't the game only get good after around 6-8 hours?...so the trial might actually have the opposite effect and turn people off
This trial is showing version 1.09. Facial animations and characters eyes look better than earlier builds I've seen on YouTube.Keep in mind that EA/BioWare are lazy. The trial we saw before was an earlier build than the one we got on launch day. I don't know if they updated the trial to a newer version or not this time around.
Played it for 3+ hours and am liking the combat and exploration. Conversations are pretty good as well. I'm not ready to hit the buy button, but it might get me hooked after a few more hours.
I mostly agree. The story is compelling enough but the execution of the story is not good enough to warrant re-playing the game. I had the same urge to skip conversations, some of the characters are just too flat. Maybe Reyes is the only that was more than a cookie cutter npc.The conversations are much deeper than they were in the older games. Unfortunately, a lot of the characters are flatter and less compelling. I'm one of those people who has played the original trilogy so many times I know what each choice results in or what every conversation sounds like. I never skip conversations in the original trilogy when replaying it. I found myself wanting to skip through conversations on the first run through of Andromeda. A lot of the conversations are just tedious. The combat is great, and I always felt like I wanted to get back to that rather than immersing myself in the story. The main quest line is good, but it lacks the gravitas of the original trilogy. Some of the new characters are great, while the rest aren't on par with what we had before. I don't have a problem with Ryder or his/her sarcastic conversation options, but you have to choose wisely here. Even then, I felt like BioWare specifically made the character less awesome than Shepard on purpose. There are times where you want to punch someone or whip out your gun, and not take anyone's shit. Instead Ryder will often back out of a situation or take a more "PC" approach to the situation for lack of a better term.
The game is good despite a long list of faults. I don't know if I'd call it $60 good, but on sale I can recommend it to any Mass Effect fan.
The game does seem like a love/hate it affair. It's too early for me too judge, but I worry the story and eventually the gameplay goes stale after 10 or 20 hours.The conversations are much deeper than they were in the older games. Unfortunately, a lot of the characters are flatter and less compelling. I'm one of those people who has played the original trilogy so many times I know what each choice results in or what every conversation sounds like. I never skip conversations in the original trilogy when replaying it. I found myself wanting to skip through conversations on the first run through of Andromeda. A lot of the conversations are just tedious. The combat is great, and I always felt like I wanted to get back to that rather than immersing myself in the story. The main quest line is good, but it lacks the gravitas of the original trilogy. Some of the new characters are great, while the rest aren't on par with what we had before. I don't have a problem with Ryder or his/her sarcastic conversation options, but you have to choose wisely here. Even then, I felt like BioWare specifically made the character less awesome than Shepard on purpose. There are times where you want to punch someone or whip out your gun, and not take anyone's shit. Instead Ryder will often back out of a situation or take a more "PC" approach to the situation for lack of a better term.
