- Aug 5, 2013
When you dismantle an item, you get back the augments. You should never lose them.And another problem I find in the game is in crafting. Early on in the game when I crafted level 2-3 weapons I could add a lot of cool modifiers to them. But since I used up those back then I wasn't able to procure the same items ever. So now I only have a bunch of useless ones that I don't even want to use for crafting. If I knew this I'd have saved the good ones for later. How do you even find these crafting mods? Is it just pure bad luck? Same goes for weapon mods. The lower level weapon mods seemed much more useful, with almost no ill effects, while the higher level ones all seem to give a little, and take away a little at the same time, making them absolutely redundant.
As for weapon mods you can take them out and re-use them whenever you want. Some mods have no negative affects (For example some barrel mods give a % Damage increase with no negatives), others have both options available where you can get higher positive affects with a little negative, or you can get slightly less of the same effects with no negatives.
