Yes, but see Chime's comments below. He's dead on.any chance of short depth version of this case? for folks with shorter card these and need a smaller footprint?
I've been messing around trying to design something like this on paper for a while, and the issue I keep running into is the power supply. You can't really shorten the case without putting the PSU over the motherboard or going with something like the PicoPSU, which presents its own problems. So you either end up with a tiny cube style case (which I wouldn't mind) or having to come up with an external power brick + PicoPSU that can supply 300+ watts.
One of my unwritten underlying goals is to not require anything too unconventional that would limit a customer's hardware selection. And the experience I've had with 1U PSUs is they are noisy. My 500W shuttle power supply (though not 1U) really wound up during gaming with it's little tiny fans.you could try using 1u powersupplies. like these
This is a real possibility. I'll have to look into those small PSU boards + power brick. Any links/suggestions?I wouldn't mind a small case that used a 200W AC-DC PSU with the 192Watt power brick. They make those small PSU boards that are better than the PICO PSUs. Especially with haswell around the corner and the way GPU power reqs are dropping it might be a good time to design a quality low powered case. I mean even right now with such a case you could do a 3750 and a 7770 which is still really powerful.
Thank you!Even though I just bought a Fractal Design Node 304, THIS is the case I've been looking for. Can't wait to see how things progress. Great work!
