cageymaru
- Apr 10, 2003
M-Audio BX5 D2 Studio Monitor (Each) for $79.99 each. Free shipping. Obviously you need 2 for a stereo setup and they are 70watts each bi amplified. Feel free to discuss the merits of the deal. Saw it on Slickdeals.net.
Product description.
Bi-amplified design with 70 watts of distributed power
5” low-frequency drivers with Kevlar cones
1” high-frequency drivers with natural silk domes and integrated waveguides
Optimized rear ports
XLR balanced and 1/4” balanced/unbalanced inputs
M-Audio BX5 D2 Studio Monitor (Each) Specifications:
Frequency response 56Hz-22kHz
Crossover frequency 3 kHz
Low-frequency amplifier power 40 watts
High-frequency amplifier power 30 watts
Maximum signal-to-noise (dynamic range) > 100 dB (typical A-weighted)
Polarity positive signal at + input produce outward LF cone displacement
Input impedance 20 k ohms balanced, 10 k ohms unbalanced
Input sensitivity 85 mV pink noise input produces 90 dBA output SPL at one meter with volume control at maximum
Power factory programmed for either 115V ~50/60 Hz or 230V ~50/60 Hz
Protection RF interference, output current limiting, over temperature, turn-on/off transient, subsonic filter, external mains fuse
Cabinet vinyl-laminated MDF
Size 7.7” x 7” x 10”; 19.5cm x 17.6cm x 25.2cm
Weight 11 lbs./unit; 5 kg.
