BigMacAttack said:Greenmonkey - try the 11x multi. I used to run 230x12 but found the 11x multi the sweet spot for both cpu and ram. Try 240x11 and then 245x11. Who knows; you may even squeeze 250x11 out of it like me. I have had no luck on the 10x multi and the 12x means my ram runs a bit too slow - even on the DDR466 divider.
EDIT
Now isn't it just like this thing to go and make a liar out of me?! I played around quite a lot with it this morning and got it to 232x12. Here are the results:
GreenMonkey said:I like the 11.5x multiplier. The extra .5 x helps make for some finer control of the mhz
I'm pretty sure I can't get any higher without bumping the voltage again. I'm not too comfy with running past 1.55v. My next voltage step is 1.65 which makes me nervous. I'm afraid of reducing the life past that point - this processor will inevitably be a hand-me-down to my wife's box at some point - she's running my old AXP 1800+/9800pro.
BigMacAttack said:That's a fine oc for only 1.55v. Too bad your next voltage bump is so high. I don't blame you for not taking it on up. I don't mind running the extra voltage because I have 2 spare 3000+ Venices in my desk drawerand a 3400+ Clawhammer if I get desperate
I know what you mean on the hand me down. I just set up my old XP2000 (upgunned to XP2400) for my wife. It has an ATI 9200 SE card in it and is still a rock solid performer.
The latest versions of CPU-Z seem to have a voltage reporting bug. Both versions 1.35 and 1.36 have this problem.Vette5885 said:CPU-Z doesn't read over 1.69V on my MoBo]
Vette5885 said:FINALLY
After 33.137, then 33.047, an even 33.000, I finally got into the 32's. Turns out the memory can do 3-4-3-4 at 250 (although this was at 240).
Chip was at 1.705 (1.55*1.1) - CPU-Z doesn't read over 1.69V on my MoBo
From what I've read, the primary 2 differences between the 754 and 939 single cores is the 1000MHz HT and Dual Channel. Considering that I have a pretty decend board, I figured I might as well run 1/2 way to 939.noobtech said:YOu had your HT Link at 4X? w000t! Is that okay that it's above 800!? What mobo are you using? I have some pretty good ram, so I wonder if I can do the same.
*edit... you have the same board that is in my wifes system... but the ram isn't as goodI will give her a try later this week. haha
Vette5885 said:From what I've read, the primary 2 differences between the 754 and 939 single cores is the 1000MHz HT and Dual Channel. Considering that I have a pretty decend board, I figured I might as well run 1/2 way to 939.
Plus, when I originally ran 250x11.5, I had it set to 3x. Moving it to 4x gained me like .01s in Super Pi. Sounds insignificant, yes, but the run right before the one pictured above was 33.000s. I really wanted to be in the 32s.
FWIW, I have the latest bios (6.00) for my DFI Lanparty UT NF3 250GB, with the board at 1.7V (up from 1.6). I also put a much better passive heat sink over the SB (I think its a Thermaltake that I got from Newegg for like $10). My VF900 seems to blow some air over it too.
Super PI isn't so much for stability as it is for benchmarking. In my tests, it seems to mimic speed changes in the processor pretty well - a 15% speed increase across the board on my computer netted a 15% time decrease with PI.cirial said:Can someone explain how they test for oc stability using Super Pi? Search didnt turn up much.. and I have only pushed my 3200+ up 200mhz so far![]()
BigMacAttack said:They should have released the 3400+ Venice into the retail channel a year ago when it was first produced instead of only releasing it to OEM builders. I guess if they had done that they never would have sold any 3000+ or 3200+ Venices though. Many thanks to Intel for initiating the price war and inspiring AMD to finally loosen their grip on this great chip!
BigMacAttack said:You're getting about what I got out of my 3000+ Venice. I was able to go to 2.65 with it which is a darn good oc for a 2.0 ghz chip. That Epox should be a good board. Are you going to go the SLI route also? (yeah I know - silly question)
Vette5885 said:Super PI isn't so much for stability as it is for benchmarking. In my tests, it seems to mimic speed changes in the processor pretty well - a 15% speed increase across the board on my computer netted a 15% time decrease with PI.
Plus, it works pretty well for your e-penis (woot! I'm in the 32 second club baby!)
For stability, I use Memtest when I push the memory, then when its safe, I go into windows and run Prime95 (I alternate between small FFTs and in-place large FFTs)
And Noobtech: Memory is 2.7v (seems to crash at 2.8, must be a heat issue), CPU is 1.705 for 2880Mhz and 1.58 for 2750, and chipset is 1.7V.
I know how to check the 12V rail, the 5V and how to check for 3.3V with a multimeter but how the heck do you check vCore with a multimeter?Unknown-One said:Check what vCore is actualy at under "PC Health Status", or better yet use a multimeter.
The only way I know of is to run a wire (shielded to avoid shorting across other pins) from the voltage pin on the processor so you can get a direct reading.unclewebb said:I know how to check the 12V rail, the 5V and how to check for 3.3V with a multimeter but how the heck do you check vCore with a multimeter?
That's kind of what I thought. I'm not that brave so I think I will stick to using the older versions of CPU-z.Unknown-One said:The only way I know of is to run a wire (shielded to avoid shorting across other pins) from the voltage pin on the processor so you can get a direct reading.
Yea, its not like the top voltage on these EPoX boards is very dangerous. These Venice chips appear to take 1.6v just fine (heck, BigMac runs his at 1.7v).unclewebb said:The best advice I have for new users is to set the CPU voltage as high as the motherboard will go. That works best for me!![]()
I ran into the same thing, I can clock higher at 11x than I can at 10 or 12.BigMacAttack said:Yeah - half-multi's haven't been too successful for me either. My 3400+ seems to like the 11x multi best...
cirial said:How are you guys unlocking multipliers? I haven't read anything about unlocking them, since back in the Socket A days of doing the "pencil trick".. anyone have any documentation that I can read up on?
