The only upgrades that you need to consider are a new video card, like the HD5850 or HD5870, and a better quality PSU to use along with it, like the new Antec TP-750 or Corsiar HX650.
If you haven't already, consider overclocking the Q6600 to around 3GHz, if not a bit higher. The long story short is that a new video card will turn the Q6600, at its stock 2.4GHz speed, into a performance bottleneck.
If you really need a new case, you can't go wrong with the Cooler Master RC-690. A new revision, known as the CM 690 II, is expected to arrive soon, but I can't tell you when.
I agree, get an HD5850.What are your load temps at 3Ghz?
I would go with a video card as well, and here's the one I would suggest.
http://www.newegg.com/Product/Product.aspx?Item=N82E16814150442
says unavailableany other suggestions?
QFT.
That Coolmax is pure crap:
http://www.jonnyguru.com/modules.php?name=NDReviews&op=Story&reid=68
$289 - VisionTek 900297 Radeon HD 5850 (Cypress Pro) 1GB 256-bit GDDR5 ($7.56 Std. Shipping)
2nd only to XFX, which has double lifetime warranty, lol.
