- Jul 17, 2006
For the TV, you can wait for the March Madness sales.
Thinking more and more on it, the 8800 GTX's price premium really isn't worth it anymore when the 8800 GTS 512MB is nearly as fast.
Finally.![]()
The stock cooling on the 8800 GT sucks, it has fewer Stream Processors, and by the time you replace the cooling... it costs the same or more than the 8800 GTS 512MB.![]()
If you get Crysis and realize your computer isn't good enough, pickup TF2 or WoW, lol.
installing crysis / orange box / cod 4 once i get home from work in 2 more hours. how is crysis going to run at max settings for my rig in sig on the left? cpu will be oc'd to 3.0ghz before i attempt to run crysis.
by the way, i find that eating a peanut butter, bacon cooked well-done, and a grilled banana all on a panini really helps get the gears going for pc procedures.
Yah, even if you don't get your SLI system, that build will still perform nicely, especially on WoW and TF2. As for Crysis, you'll just need to turn down the settings, and it all depends on what you consider playable. Personally, I can't play CS/CSS/TF2 without 100FPS, while others are fine with 60.
Don't agree with the above build.
650i SLI is... blah, and at 1920x1200 the 8800 GTX is a better choice than the 8800 GTS 512MB, though there's no denying the price is good on the MSI cards, and I could probably get behind them for budget reasons.
I also am not a fan of ASUS, so their "value" brand is even worse in my eyes. No ASRock stuff.
Even at 950 watts, without knowing the OEM for that Rosewill PSU I wouldn't touch it with a 10 foot pole.
So there isn't a noticeable difference between two GTXs and two GTSs?
Nope, not unless you're running 25xx by something on one of those 30" Dells that cost about 1/2 your budget... and even then, just barely.
I agree with Silent -- thumbs down to the ASRock. Despite what AnandTech said about that board, I would be very wary about building a system around it. It's not a good option for a high end SLI setup. Also, 380FSB on a quad is quite weak. The reference 780i boards and the P7N Diamond will do 400-450mhz w/o issue.
Note that the P7N is $229 with discount at newegg. If you want cheaper SLI, a 750 board, such as the ASUS P5N-D or the MSI P7N Platinum, would be a good option.
Can't comment on the PSU since I don't know anything about it, although I too would hesitate to buy a Rosewill.
Since you're getting a nice 24" monitor, you can pickup a TV Tuner card and watch TV on your PC.![]()
The Asrock is still cheaper, offers a better featureset, and offers overclockability needed by a Q6600 to reach its maximum potential. However, since it seems irreputable, I wouldn't go for it.
SLI Build
(17 items)
OCZ SLI-Ready Edition 4GB(2 x 2GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory - $107.99 (( ZipZoomFly )) -$30 MIR
MSI P7N Diamond LGA 775 NVIDIA nForce 780i SLI ATX Intel Motherboard with SoundBlaster X-Fi Extreme Audio -$259.99 -$30 MIR
Thermaltake Armor Series VA8003BWS Black Full Tower Case w/ 25CM Fan -$154.99 -$25 MIR
CORSAIR CMPSU-750TX TX 750W Power Supply Retail - $155 -$35 MIR (( ZipZoomFly ))
Intel Core 2 Quad Q6600 Kentsfield 2.4GHz 775 Quad-Core Processor - $254.99 (( Clubit.com ))
2x EVGA 512-P3-N841-A3 GeForce 8800GTS (G92) 512MB 256-bit GDDR3 PCI Express 2.0 x16 HDCP Ready SLI Supported Video Card - $299.99 -$30 MIR ($599.98... $60 MIR)
Western Digital Caviar SE16 WD5000AAKS 500GB 7200 RPM SATA 3.0Gb/s Hard Drive - $99.99
SAMSUNG 20X DVD±R DVD Burner with LightScribe Black SATA Model SH-S203N - $33.99
Creative 70SB046A00000 7.1 Channels PCI Interface Sound Blaster X-Fi XtremeGamer Fatal1ty Professional Series - $135.99 -$50 MIR
Logitech Z-5500 505 Watts 5.1 Speakers - $229.99 (( ClubIt.com ))
ZEROtherm Nirvana NV120 120mm 2-ball UFO Bearing / Transparent CPU Cooler - $45.99 -$10 MIR
SAMSUNG 24ST-BLACK Black 24" 6ms HDMI Widescreen HSMI LCD Monitor - $659.99
Microsoft Windows Vista 64-Bit Home Premium for System Builders Single Pack DVD - $109.99
CORSAIR Flash Voyager 2GB Flash Drive (USB2.0 Portable) Model CMFUSB2.0-2GB - $14.99
Arctic Silver Ceramique Thermal Compound - $4.99
BELKIN BE112234-10 10 feet 12 Outlets 4120 joule Surge Suppressor with Phone/Modem, RJ45 and Coax Protection - $34.99
I was comparing the Asrock vs 750i cards. The Asrock has Wi-fi and a better audio chipset:
http://www.newegg.com/Product/Productcompare.aspx?Submit=Property&N=2000200280&PropertyCodeValue=717%3A26983%2C717%3A33942&bop=And&CompareItemList=N82E16813157120%2CN82E16813130159%2CN82E16813131232
Also, the OP is buying a Q6600, so talk about Q9650 is off-topic.
The Asrock is a fully featured mobo that does 380FSB on a QX9650. I believe it can atleast do the same with a Q6600.
http://www.anandtech.com/mb/showdoc.aspx?i=3227&p=1
I'd say your good to go, although I personally would go for a different case. Of course, case preference is most subjective, so you shouldn't consider an alternative unless you aren't completely happen with the Armor and haven't yet looked at alternatives.
For a setup like this, having airflow over the graphics cards is important. The Silverstone TJ-09, CoolerMaster Cosmos (and S series,) and the Lian Li PC-A77 are just three examples of cases which have mid-case air intake mechanisms to keep the cards cool. Not sure if the Thermaltake does. I would just double check reviews to make sure that it keeps videocards from getting too warm
Good luck on building everything. Be sure to post pics!
Isn't that monitor better than the Samsung that I'm getting?
