Logitech MX518 $29.99
Walking around Target and saw a temporary price cut on it until the 1st of October for $29.99. Looked online and the price is not the same so, in-store only. Figured since it usually goes for 40 at the egg, this deal was mentionable.
This is the mouse I use, works great with an Everglide Titan mousepad :).
I play Cal-0 Cal-M counter-strike source and use the mx518 exclusively. I have owned a lot of mice including the G5, G7, and razor copperhead. This one is still my favorite. The grip is perfect and it has the most buttons which isn't important for most but, it works better for me.
I searched on Target.com and found MX518SE . what is the difference between MX518SE and regular MX518 beside color?
Can someone else confirm if MX518SE costs $29 at the local store since it shows full price online? Or is it just price mistake at one store?
It's not the SE that is in-store for $29, it's the regular. The SE is only avaible online, or possibly at a bigger Target, like a SuperTarget, because they might have a bigger selection. I can't confirm that it's $29 at another store, but I work there and "Temporary Price Cuts" (signified by the yellow 3x5 signs) generally run the same at all stores.
I'm not so sure. I just picked up the MX518SE at Target for $29.99 (price cut). Just for reference, the mouse is red. I didn't see a regular MX518 there either. Perhaps it varies from location to location?
It looks like the only difference between the SE and standard is that it's red.
I called a couple Target store in charllote, NC but none had MX mouse (SE or regular).
For those of you who already have this mouse, does your scroll wheel sound loud as hell? I picked one up a little while ago, and it's driving me nuts.
My scroll wheel is silent.
I've had this one quite a while (2+ years) and the pads on the bottom are pretty nasty, so I might pick up another one. Thanks OP.
I think the 518 is a superior gaming mouse ot the G5.
The G5 is nice for browsing, but the two thumb buttons and slightly smaller size of the 518 make it better.
Same exact thing, with this amazing gripping material that holds up to the most sweaty and intense gaming sessions with ease. It's a great looking mouse, really. And it now features a 1000 Mhz polling rate as well.
http://www.newegg.com/Product/Product.aspx?Item=N82E16826104076
Get it at Provantage.com for cheap.
edit: Well, when I got it it was cheap. They now have it for $53. I got it for $39 :)
I hated that feel of the G5... I sucked balls playing games, went back to my 518 and I was perfect...
I might have to pick one up, my 518 is wearing down... I've used it so much that the "grip" material is wearing off :eek: (about 2 years of playing)
1 left at Burbank ~6:00pm
thanks OP, time to replace my MX500 ( this is noticable lighter :))
It's quiter than all my mouse here MX500, MX1000 (not much to compare with)
little off topic:
since my MX500 is still good, does anyone know place, that just sells the cover...it's a little beat, and I want to use it for my laptop.
G5 revision 2 is NOT the same exact thing as an MX518. No no no. G5 Rev. 2's texture is disgusting (rev1 was great... I admit rev2 looks cooler though) and the click wheel is too obtrusive and uncomfortable.. it really protrudes from the mouse and is arduous to use. Plus they removed the other button. MX518 has 8 clickable buttons. (Yes, I know G5 technically has 9, but who the hell uses the scroll wheel's left and right as buttons, especially a scroll wheel like the G5's?)
MX518 FTW.
Amen! FUCK that middle mouse button on the G5. Not only does it stick out making it really hard to "click" with due to it's side scrolling ability, but it SUCKS at tracking your scrolling. You can roll it over and it won't quite register the scroll, but the next time you go middle click, it scrolls as you click. Hate that mouse. MX518 wins hands down imo.
Good find! I have been meaning to buy a backup MX518 just in case something happens to my current one.
For anyone out there using pretty much any Logitech mouse (and/or keyboard), you might want to give uberoptions a try. It adds a LOT more versatility than the standard Logitech SetPoint options (it's basically a modded SetPoint). This makes it possible to set ANY key to do just about anything in any application. The nice thing is that it allows you to set all your mouse buttons in a game where the game might not recognize the button (i.e.: the button above and below the scroll wheel). Really handy app, and a great addition to Logitech mice.
MX518 FTW.
He asked if it was similar to the first G5.
And it's texture is amazing IMO.
And cre3d, I've never experienced any of those problems with the wheel. Mine's been perfect.
For $15 or so more, you can get a G5 Revision 2.
$5 for the roller blade mouse wheel :p
$5 for spiderman's sandpaper grip :(
$5 for the lack of precision courtesy of the laser engine :mad:
G5 Rev. 2's texture is disgusting... and the click wheel is too obtrusive...
Hey! I'm not alone! :D In all seriousness, I've used and disliked the MX1000, G5, G5 Spidey edition, Copperhead, and G7 because of their inability to track my movements. The MX518 and even better, the Deathadder never fail when it comes to quick/slow tracking in a shooter. It's all about the Infrared LED IMO.
...uberoptions... ...it allows you to set all your mouse buttons in a game where the game might not recognize the button (i.e.: the button above and below the scroll wheel)....
QFT!! Is there an uberoption thread here or @ logi's forums? If not, here's my setup:
dpi +/-: volume up/down, you basically hold a button and it'll continually raise/lower the main sound volume w/ a nice little OSD.
task switcher: alt-tab, nothing better than switching between a pair of fullscreen windows w/ a slight touch of the index finger!
Then I'll usually bind all of the keys to ;',./ for games. This gives me map zoom, map, and knife in addition to the mwheel up/down, mouse 1-5! That's a whole lot of functionality from a mouse, eh?
I'd also like to add Hyperglides's MX-1 skates to this thread. For less than $10 bucks you'll get 2 pairs of the best sliding mouse feet. I removed my old pads before putting these on and it def brought new life to this mouse. Combined w/ an Exactmat, it's an FPS control freak's dream!
Content with the G5 rev. 2. It feels a little squirrely no matter which sensitivity setting I use, but I eventually manage. It feels like I have to re-learn how to use it every time I get on it. The wheel button sucks ass. Can no longer bind a function to it when I game without inadvertently changing my weapon or something.
I actually like the texture. Unlike my MX-500, I don't get anymore grime and dirt trapped in the nooks. The texture quickly evaporates the sweat from my palms (heh) and doesn't allow dirt to stick. I use the weights too, but not that they really make a difference. The blue goes with the glow on my G15 and the blue LCD on my X-Dreamer II. :)
$39.99 at my Southeast VA store. :(
I tried the G5 for awhile too, but didn't like it for gaming. Went back to my 518, but the feet pads got pretty worn out. Using the corepad skates right now with a Thunder9 mousepad. I don't recommend theses skate though. My first set didn't last long and when the second set craps out, I'll try the hyperglides.
anyone know if any target store in NC carry the MX518? I called around but none has it.
FWIW: Target's had the MX518 for 39.99, but it rings up as 29.99 for over 3 months now. I think it's a regular price!
so it sounds like most of you guys prefer this to the G5 rev. 1?
I have the G5 and truthfully... I don't really like it. The only game I play is BF2 (maybe once a week)... I think I'm a little more accurate with it, but I don't like how it feels in my hand.
Also, I really preferred my inteli-mouse explorer 3.0 for web browsing. Maybe this is a happy medium?
Are the G5 and MX518 not the same body? I've had my MX700 for four years or so now, and I've grown accustomed to it and I really like it in my hand. I have big hands though. I need a new mouse 'cause it's starting to show its wear. It has shoddy response and sometimes in an FPS I'll fire at someone and my gun keeps firing long after I've lifted from the left mouse button. Now I'm quite positive I wanna go back to wired.
Have any of you gone from an MX700 to a G5? What are your thoughts?
I hate corded mice, waiting for a decent improved replacement of the MX1000 still.
Love my MX1000 + Corepad.
