vroom_skies
- Sep 25, 2005
Hey all,
Here is a link to the case:
http://www.newegg.com/Product/Product.aspx?Item=N82E16811112355
I'm on the verge of buying this case but am having a hard time finding out if my graphic cards will fit. I plan on running two MSI 680 Lightnings in SLI.
http://www.msi.com/product/vga/N680GTX-Lightning.html#?div=Specification
The cards are said to be 280mm long or 11.02 inches.
The case says it can fit up to 295mm, but that looks to be at the 5.25 inch drives and not the hard drive rack below, which looks like there is less space. I've also seen this case with a GTX 670 which was 241.3mm or 9.5 inch card and the fit looked very tight, so I have my doubts that the 680's will fit.
Does anyone happen to know if the hard drive rack in this case removable or no?
Thanks for the help in advance,
Bob
Bob
