New 245BW? I didn't know there was a new one. IF you are talking about the TN version of the panel... there is no what that it has better viewing angles than the MVA panel the LG has.
also anyone else's bezel at the bottom right corner (or any corner). Is it firmly attached to the back piece of plasticfor you? It doesn't affect anything just looks like the bezel is not firmly seated compared to the other corners
Going through this thread too and a few people have had this issue. Just debating if i should go back and exchange it for another
went back and exchanged it, this one is perfect
I just got another one of these. This time its for work. I never should have returned the last one I had. Mine is a March, 2007 model. I took a look at the service menu and it claims that this monitor is a 245WP (I know that the 245 and 246 are only cosmetically different) and gives a 06/11/02 date V1.420. Accidentally hit the Nvram Initial button. Hopefully it didn't do anything.
I do get a buzzing noise with this model if the brightness is not at 100. I have to turn the monitor completely around and put my ear next to the rear grill to clearly hear. It is so strange. At 100 brightness there is no noise, and as soon as it hits 98, it appears. Viewing this monitor from a foot and a half, I can't hear it even if I strain my ears. There is some ambient noise at the office I work, but it is very quiet. My monitor has no dead or stuck pixels and absolutely pristine back light which I care about more.
Edit: My monitor was not V 1.420, It was actually V 1.440
Has anyone had a problem with this monitor blanking out for 1-2 seconds every once in a while? I'm on my 4th L246WP, this one from Frys.com, and the panel so far doesn't have any dead pixels or other obvious issues I've had with the previous 3 from Best Buy. I'm hoping this isn't a defect with my new monitor.
This one from Frys.com was manufactured in April 2007. For the other interested person, the serial number outside the box started with 704, so it sounds likely that it is year followed by month.
I came across another thread in this forum about other users of the BenQ FP241W monitors having 1-2 second blackouts:
http://www.hardforum.com/showthread.php?t=1178150
I think the BenQ FP241W uses the same panel as the LG L246WP. But I'll have to keep searching to see if the problem is related to the LCD panel, the graphics card and drivers, or cables.
OK you guys are going to love this. Talk about flip-flopping. OK here goes!
So I had returned my 2nd LG to Best Buy for buzzing issues, and picked up the Samsung 245BW. I liked it a lot, and said so here. No buzzing that's audible.
HOWEVER, using it for a few hours, my eyes just weren't happy. Something about the picture of the Samsung is...harsh. It's like I can't get it smooth enough without making it blurry, and when it's sharp it just hurts my eyes. I also detect a bit of....moire (for lack of a better word) around text. Almost like red/green color tinges. Yes, the screen was 100% calibrated when I saw this.
I decided to take the screen LG had sent me, back out of the box to compare again. Ahhh, the "warmth" of the LG felt much better to my eyes. However, the buzzing in sRGB mode drove me crazy within seconds. Then, for whatever reason, I switched the picture mode to USER, and no matter what brightness setting I use, there's NO MORE BUZZING! I'm sure my first 2 LGs had buzzing no matter what mode I used (at less than 100 brightness), but for some reason this April 2007 model has no buzzing in USER mode at any brightness setting.
So, I think I'm going to stick with the LG. As I had said way earlier in the thread, it is a great screen, but there's no way I'd have kept it if it kept buzzing. I calibrated the screen in OS X 10.5 Leopard, and it looks fabulous. sRGB mode looks identical to my eyes when calibrated, though the buzzing is ghastly. So, looks like the Samsung goes back, and the LG is mine once again. Wonder how much LG will charge me for keeping it?
Thanks for reading.
Sounds great that your happy with the LG. I have secured an October 2007 rev2 model now though so am hopeing that SRGB mode will work great.
I would like to know what is changed in Rev 2 monitor. I hope the minor overscan issue's are fixed too.
Also I had a really weird moment.
When I was going to switch my PC HDMI signal back into the monitor, it wouldn't accept it. It'd give the "no signal" and go into stand-by. When I put the PS3 HDMI signal in, it'd pick it up instantly with no problems, but for some reason would not take the PC signal.
About 10 minutes later is randomly took it, and I still have no clue why it did this and how it happened. Is there some instruction on how to properly switch HDMI cables back and forth on this display?
Update your video card drivers.
Also, pick up a HDMI switch if you want to keep both your PC and your PS3 connected at the same time.
I just got the HDMI cable for my PS3 today, and I wanna make sure I'm doing this right?
I have my computer hooked up via HDMI, so do I always have to take out the signal from my PC in order to use HDMI slot for the PS3? Kind of a hassle.
Also, how do I properly go about getting audio from the PS3 with HDMI? I ended up putting my speakers through the green jack on the left of the display, and it seemed to work fine, although I was confused on what exactly to select in the PS3 menu about what audio signal I was using (dolby, linear, pcm, etc)
Kind of a drag, cause I'm so used to being able to use my 360 through VGA in a click of 2 buttons, but oh well.
and yes the only way to get audio out of your HDMI input is via that audio output on the side of the panel... if you have a speaker set that accepts optical input you can hook that up, then goto in the PS3 menu and change sound output from HDMI to Optical... that way the video will still go through HDMI but audio will now be outputted to the Optical cable.
so which monitor would you guys say is better? benq fp241 or the lg?
