- May 18, 1997
LG is showing off its new "rollable" TV screen that does not require a backlight while using OLED technology. While the practicality of actually needing or wanting a roll-up TV screen in your casa, it does actually have some cool features. On the upside, you can put a picture of your mother-in-law behind it and most likely never have to look at it as you will probably not be rolling up your TV too often.
Check out the video.
LG Display has created the world's first large, rollable, ultra-high definition screen. The 4K display uses OLED technology, allowing it to be more flexible than a conventional LED television.
