Project ID: 6012
Core: GRO-A3
Credit: 470
Frames: 100
Number of Frames Observed: 300
Min. Time / Frame : 00:09:07 - 3,232 PPD
Avg. Time / Frame : 00:10:29 - 2,621 PPD
Hmmm. do I or don't I?
yes i wanna see that moster at work
any particular reason you're not folding bigadv on that baby?
Are you talkin' about me? How about 2 bigadvs.
do you make your own bigadv setup or use the evga one? and those numbers are friggen sick.Are you talkin' about me? How about 2 bigadvs.
I tried to go a little farther but It bluescreened so I gave it a bit more vcore which fixed that but once I thought I had it stable FAH threw a floating point error. So I am leaving it alone at 4.2 until I feel adventurous again.Out of curiosity, did you try taking your Gulftown past 4.2ghz and cranking up the juice? Those temps are just crazy because they are so good. I'm wondering how much more room there was. Still can't believe you can actually run 2 -bigadv's at the same time running simultaneously in VM's. Just imagine how awesome your rig will be when bigadv wu's come to the windows SMP client.
I tride 8 ways to sunday to get this thing faster than 4.0 but it blue screens @ 200x20 or or 190x21 but runs all day long at 215x19@ 1.35 volts. tride voltage as high as 1.45. though 4.0 is about the max for my cooling. i wanna see 2:30 fram times or 20,000ppd in smp been as low as 2.43 and 19,300ppd
do you have a C0 i7?
i couldn't get mine stable with 20x or 21x CPU mult. though so far it appears to be bigadv stable @ 200x19 @ 1.275 volts. never thought to try bumping BCLK above 200.
what speed/volts is your memory running at? 1720mhz/1.65v?
I have Ubuntu 9.10 installed and had it set up to fold while I was on vacation last month. It worked fine but I heard that 9.10 was not that good. Any suggestions on another version to try?
I use Ubuntu 9.04 for all of mine. I had problems getting FAH to use all of my processor cores with 9.10. If you are getting 100% load, I wouldn't change.
