Lepa cpu cooler
Lepa is a decent budget brand, but I wouldn't use a 120mm AIO unless you were REALLY space constrained. Try for 240/280mm.
Never used any liquid cooling.
My option is 120mm, 140mm and 240mm to the top of a case.
Does the size make that much of difference?
My chip will be 120 to 150w or not likely but a Threadripper with 180w.
What a cluster that ad is at Fry's. They have a 120mm radiator, a 240mm radiator, and a Corsair H105 when you click the product links.
You'll want a 240mm. The Arctic Cooler liquid freezer is amazing, but make sure you have enough space for the double fans. Another option would be the Coolermaster Masterliquid 240mm, which is cheap as dirt and works really well. I have one in my 8700k rig. I got mine on Amazon for $40 after rebate.
