Hi, I received my CRS305-1G-4S+IN yesterday and carried out the updates, set my ip but have not been able to connect to it since! I have performed about 30 resets and cannot connect to the unit at all.
I only have the poe connected through my laptop and set my laptop IP to 192.168.88.59 and tried holding the reset button, turning on releasing after led's start blinking, also tried holding for longer, releasing at different times but cannot connect? After it has booted the power LED is on and the "E" LED is blinking but when pinging 192.168.88.1 I get either "Request timed out" or "Reply from 192.168.88.59: Destination host unreachable.
Have I killed it?
Thank you
Can you try a subnet scan to see if it has some other IP on the subnet you set it to or on the default 192.168.88.x subnet?
