LightSource
- Jul 21, 2005
I've been having problems with my system the last few months. Sometimes when I turn it on it will hang and the monitor light will stay orange. I hit the reset button and it will usually boot as it should. Some times it will hang durring the Windows XP welcome screen. My main problem is running Google Earth and World Wind. A few seconds after I start either program my system will reboot as if someone hit the reset button. While cleaning the dust out of my system this afternoon I noticed a few of the capacitors had this rusty looking corrosion on top. I guessing this may be the cause of some of my problems.
The cap in the upper left hand corner between the PS2 ports and the CPU looks the worst with some rusty looking residue on the motherboard it's self around the base of the cap.
I've never seen this on a mobo before it may be common on old systems, I don't know. I'm intending to build a new system around the end of this year or the beginning of 07. I want to hold out for the AMD quad core but I doubt I will be able to the way my system keeps going.
I built my system on Dec. 24, 2000. It is a 1.0GHz AMD Athlon Thunderbird processor, 512MB RAM, ABIT KT7 Raid motherboard, GeForce 3 Ti 500 GFX Card, Sound Blaster Audigy sound card. Yeah it's old.
