ecmaster76
- Feb 6, 2007
That bench shows it keeping up with dual socket Xeons. You rushing Shintai?
From 2010.That bench shows it keeping up with dual socket Xeons. You rushing Shintai?
What i find most hilarious is that the first AotS leak on the very first ES was actually right on point about CPU performance.Said it right from the start, if they aren't showing things clearly, there is smoke
From 2010.
When we approached AMD with these results pre-publication, the company defended its product by suggesting that intentionally creating a GPU bottleneck (read: no longer benchmarking the CPU’s performance) would serve as a great equalizer. AMD asked that we consider 4K benchmarks to more heavily load the GPU, thus reducing workload on the CPU and leveling the playing field.
Again from gamer's nexus. Another page I need to bookmark for future discussions about AMD and it's benevolence and exemplary track record of marketing honesty yadiyadayada
Something else is up with that tbh.Max oveclock on a Noctuna 14, what was ball's saying, he was going to get 4.2-4.4 ghz lol, they got 3.9!
They are being hit by the high voltage and so impacting XFR.I'm slightly confused about the clocks to be honest, how are some reviews stuck at 3.95ghz when XFR is supposed to go to 4.1
Is XFR single core only? Does it only work for short bursts?
Fair enough, as for the voltages it was my understanding that they are being misrepresented by the bios. Are the chips actually running 1.4v out the box?Its all variable, XFR is just like auto boosting in GPU's depending on the applications, depending on exterior conditions.....
There are multiple reviews showing the same thing, yeah you can remove an outlier here and there, but still that doesn't change the facts.
Where? Not a single review i has seen put FX anywhere above dumpster.You refuse to deal with the impossibility of the FX 8370 being better in these games than Ryzen which has 52% IPC advanatage and SMT advantage over FX8370.
From what you can read, he has a separate dual socket rig for actual work. Ryzen does not exactly constitute a good workstation for people who are not that budget constrained.he sounds a little to mature to use his compouter only for games.
The only one who is grossly naive and thinking AMD have not done more spinning so far is you. With lack of CS knowledge too.15% is acceptable it puts it around Broadwell levels. I assume that is mostly for single core games. If a game tested favors Kaby Lake when more than 8 threads are involved it was not tested properly period. If you don't think some of these reviews you clowns are posting are not skewed by reviewers getting favors from Intel you are grossly naive.
Ryzen trhottles at 75C it seems.
Before throwing eggs, you gotta pick one up, so where is the screen you are talking about.So clown explain how an lowlu FX870 id better in the games and apps you displayed than a Ryzen 1800X. Until you give an acceptable explanation, I say the tests are flawed in methodology.
I was in class at the time, report them. Besides, it is actually possible to create a scenario in which Ryzen will perform worse than Bulldozer, by abusing CCX interconnect.Earlier today in the morning Shintai posted a bunch of tests showing various cous.
How far was 7700k ahead?In a couple of these tests the FX 8370 out performed Ryzen 1800X. That is sn impossibility and yet the clown is yet to exlain why.
You refuse to deal with the impossibility of the FX 8370 being better in these games than Ryzen which has 52% IPC advanatage and SMT advantage over FX8370. Until you explain this you all are full of crap as far as I am concerned.
15% is acceptable it puts it around Broadwell levels. I assume that is mostly for single core games. If a game tested favors Kaby Lake when more than 8 threads are involved it was not tested properly period. If you don't think some of these reviews you clowns are posting are not skewed by reviewers getting favors from Intel you are grossly naive. I guess razor 1 is only a gamester although he sounds a little to mature to use his compouter only for games. Where are the reviews with productivity apps. Don't throw those shit ptograms like winrar and seven zip intothe equation . They are antiquated . Give me a winzip test. You clowns only show the few pathetic apps that Intel does better in you are fighting a losing battle. 8 core
cores are the future of computer use and gaming. As soon as more Vulcan-base games appear like Bethesdas inventory the other game developers will fall in line. Then you can beat your breasts ragged and you will whistling in the wind. Pathetic. By the way how much Intel stock do you own????
What I am saying is there were bios updates as late as yesterday that would have improved memory performance. Did any of these reviewers update their bios to give a more accurate evaluation of Ryzen? I don't think so.Its not at Broadwell levels with IPC, at least not what we have seen thus far, need to see whats up with specific apps/games to get a better picture. Is it better than before, hell ya, but to sit here and deny that all the reviews got it wrong and only accept what AMD has shown us in their controlled tests, is far from the truth.
I do a ton of 3d rendering and special effects, but I already have a dual Broadwell system, so yeah Ryzen if I was in the market for a dev or video editing or systems like that for cheap I would be all over it if it had dual cpu's (will never go back to single cpu's for the things I do), but I'm not.
Sure! Pretty informative read for me :
https://forums.anandtech.com/threads/ryzen-strictly-technical.2500572/
The northbridge of Zeppelin is officially called as the data fabric (DF). The DF frequency is always linked to the operating frequency of the memory controller with a ratio of 1:2 (e.g. DDR4-2667 MEMCLK = 1333MHz DFICLK). This means that the memory speed will directly affect the data fabric performance as well. In some cases, it may appear that the performance of Zeppelin scales extremely well with the increased memory speed, however that is necessarily not the case.
In many of these cases the abnormally good scaling is caused by the higher data fabric clock (DFICLK) resulting from the higher memory speed, rather than the increased performance of the memory itself.
Might make more of a difference than you think. I'm not expecting miraculous improvements but then again you don't know until you try. From the other thread:
So slow RAM makes the L3 latency between CCXs go up. Starting to see a pattern here...
Ryzen trottles at 75C it seems.
That is a only part of the problem, that is not where the problem lies with Ryzen's gaming performance at all.
Bios, Microcode, all that stuff is not going to fix this problem from the looks of it. There seems to be specific architectural problems that is the underlying cause we have benchmarks with motherboards that did have higher mem bandwidth still exhibiting the same problems.
Well that is why we should take those reviews out of the mix cause yeah those reviews are the ones that really show weird results. But even without those reviews, you still have a massive gap in performance that was kinda of unexpected at least to the degree that we are seeing.
Anyway, all in all good showing from AMD. Seems to perform very competitively for productivity specifically video editing and CPU render but question of why performance is all over the place remains (not games)
This is strictly a bios issue that will be resolved in the next 3 to 4 weeks. Then faster ram speeds for 4 modules will work and game scores will increase by 10 to 15%. The remaining deficits will be erased with optimization with Vulcan. AMD is lining up additional developers to collaborate on this venture. Bethesda was the first, it will not be the last.
Baloney, it is NOT architectural at all. The games need optimization for Ryzen the same way developers optimize their code for Intel. It can be done and it will be done through Vulcan. Bethesda one of the biggest developers announced collaboration with AMD to optimize the entirety of their large stock of games. Other developers will follow. It is in their interest to do so. Once that ball starts rolling you will see that there will be little to complain about Ryzen. The only real critique of Ryzen is that it has limited overclocking. That will improve in the next stepping release. The power of the Ryzen cores is a great achievement and the cache is superb. There will be no need to turn off cache for performance improvements once optimization occurs.
The memory speeds yes but not the CCX issue.
I can sit here and go through it with you but it will be above you head, so far you are still in denial in everything about Ryzen, so its not even worth the time or effort.
