So true, I knew it had to be a fixable issue since it clearly worked over VGA. It amazes me how the "new tech" screws things up and it hasnt been addresed especially since 1000's of people every year swap to HDTV's as monitors, see this blurry ugly mess and return their sets.
Its not a fix my Mother could do either. ( If it doesnt involve turning the channel she is hosed! ) But.. upon reading the threads here and linked in this thread it became very clear what the issue was in a way that was easily understood.
The only problem I had was atcually finding my models EDID code.
Phoenix EDID didnt do it for me ( or I could not find where in that utility )
Monitor asset Manager had an easier layout to see the string you needed
The problem I then ran into what how those numbers are broken out and which of them to actually use. It took a little back and forth reading to understand which sets of numbers to place in the registry code.
Honestly I still dont fully understand what they meant, or what all the other numbers mean for that matter. I know it worked and Im typing this on 32" of goodness!
BTW.. for those deciding on 32 vs 37. Looking at this tv now I think its perfect. 37 would have been far too large. It does dwarf my 24 though which Ive been using for many years and I love it.
Its sitting right next to this existing TV hooked up to my laptop.
Side note Question ( a bit off topic ):
If you set up dual monitors and use the "extend my screen" function. Does it effect quality on the main screen? I tried it out and it sure is handly to "throw" windows over to a second monitor and thats all I want to use it for.
Should I want a full setup , yes Id buy an identicle sized 32 like this new one, but.. Am I taking away from the quality of my main 32" monitor by using this extend feature?
