officermartinez
- Jan 21, 2006
Woke up and ordered some modders mesh for all four of my 120mm fans. I also placed an order for (2) Scythe SY1212SL12H 120mm Case Fans (Newegg Item # N82E16835185139). I see they are probably going to be pretty loud so I'll more than likely have them hooked up to a fan controller (I have several different ones laying around in my stack of unused computer parts). While I was at it, I went ahead and ordered the Scythe Big Shuriken SCBSK-1000 120mm CPU Cooler (Newegg Item # N82E16835185129). I "should" have plenty of room to use a normal 120mm x 25mm size fan if I don't like the supplied Scythe low profile CPU fan that comes with that cooler. This morning, I cut up an old Lian Li 120mm fan grill and covered the backside 80mm hole. Used a few pop rivets and viola.. I like the look of it so I probably will just leave it all in there when I send it to the powder coater.
