Kingston Transforms USB Flash Drive into Active Storage Device
HardOCP News
[H] News
Kingston Digital, Inc., the Flash memory affiliate of Kingston Technology Company, Inc., the independent world leader in memory products, today announced urDrive, a free pre-loaded application available on a variety of its DataTraveler® USB Flash drives. urDrive transforms USB drives from passive storage to engaged, active storage, allowing consumers to easily access and organize their personal files, photos, music, games and videos. A built-in photo viewer and MP3 player makes looking at pictures and listening to music easy.
A USB flash drive that gives you an app store. Yea, I can't possibly see how this is used to generate reoccurring revenue.
If companies are seriously going to start pushing app stores onto people, they could at least give a discount on the hardware.
Uh, correct me if I'm wrong, but aren't usb drives already active? What is the value here? They already store data that can be accessed as if they are already a drive themselves no? Are they going to be faster with urDrive? I'm thinking a big fat no.
what i found funny is a USB drive that stores your files out on a internet site for storage for you to have access to them from anywhere. um... isn't that what the USB drive is for to begin with? why do i need to save my files out on a site to take them with me.
ha so this is almost exactly the same thing as sandisk's U3 drives (that they don't make anymore cause M$ bought U3 and killed it basically)
anyways I got a couple of the U3 drives seems like 4years ago..
A USB drive with preloaded crap? No thanks. I'd like mine empty so I can fill them up with por...er.....data.
I don't really care about the tech of these devices....
What's got my attention is if Apple is going to go after them for calling it the "App Store" like they did with Amazon :) .
... ok, I just check out the urDrive store site... they don't refer to it as the "app store" there, but "AppZone".
I guess the video was a little old...
Yeah, I remember those U3s. The idea was interesting - have a bunch of mobile versions of applications that you ported around with you that remembered your preferences and favorites (which, come to think of it now, probably a huge security issue).
However... the mobile apps weren't that compelling, mostly on account of being outpaced by the non-mobile equivalents in features, and the included on-drive security software had an annual subscription fee, so they quickly became wasted space. That and, wasn't there some trick the drive pulled to show itself to the system as a CD to activate auto-run (another security no-no)?
Yes. I removed that U3 crap on both of my drives asap.
Ugh. I remember these. I wound up with a couple accidentally. Spent time researching and cleaning that crap off them.
Stuff like this should be banned.
Portableapps.com achieves that pretty well today, without all that "take over your thumbdrive/computer" crap.
More reason to insantly wipe any drive before using it. If I needed "helper" apps I'd install them thanks.
I know!
As I recall it was not as straight forward to remove U3 as just wiping the drive. Hopefully this Kingston software will be easier to nuke.
