nice video to prove that it is working fine
Well it was not working until he replace the thermal paste.
Here is a video before I sent it back to
https://youtu.be/gynhMLZan_c
or because I did not clean the previous TIM with alcohol.
wow...scary. would it be possible that you messed up applying the new thermal paste?
You have to clean both the chip and the sink of previous TIM before applying new. The old crusty stuff will prevent a good seal.
Sometimes after a re-thermal paste and you have to screw the heat sink back on, depending on how you screw it (usually light tension diagonally), one of the side of the screw may not align with the threads on the mount so it's got a gap in between the copper plate and the gpu ihs.
This happened when I was installing a aftermarket HS on a 8800GT 512m. I re installed and it worked. On this though... I offered a exchange and he milked me for $25. I want my $25 back for wasting my time or a prepaid label. Take it or leave it. Every time you argue the price goes up for the frustration factor. You insult me, make another attack, or give me some story. The price goes up. Use this thread. No PMs, texts, or emails. You know my address. I am waiting for your response.
$30
I want resolution to this mess just as bad as you. I have my terms and sticking to them. You denied a exchange which I would have done in the first place but you seem to not understand what I tell you. You are now wasting my time. Label or money. Next time it is just me asking for the money that you obviously like wasting. The card is fixed and you failed when you tried to fix it. If you did not have everything or have never done this before. Then you should have PM'd me then about it. Now it is too late to be playing the sob story with me. Be a grown up take the lumps of your bad decisions. You had multiple outs and squandered each one. You are the only one holding up the final push for you to get the card. Are you sending a label or are you paying me? Simple question with a simple answer.
Alright I will send you label when I get home.
Here we are again. This card still overheats. I run kombuster and within seconds, it reach to100degree.
youtube video on the bottom of the post. I dont know what to say. I dont want to accuse him, but looks like some1 is trying to be sleek. I have one idea how would this happen after he posted the video running the card around 65C.
http://youtu.be/MRk-FR6OVtE
Wow. Just the way you two both handled this puts both of you on my DNT list.
However, Pickles, the way you, very clearly stated that "you have proof, if you have issues, take it up with USPS, I'm packing it bare minimum" makes it sound like you may have vandalized the card in order to "teach him a lesson" as you've been preaching. Obviously, no proof on that, but it comes off very suspicious.
Turk, if I were you, I'd simply admit that you screwed up reapplying the TIM, get some rubbing alcohol, clean it all off and reapply. If that doesnt work, claim USPS insurance and do an RMA.
You both are being kind of ridiculous. Especially when the package was insured. I can honestly say that you've both probably wasted more time than the card was worth at this point.
I don't want to imply anything here, but Turk-FX, I gotta ask this since I know you run a couple mining rigs and I can see right in the background of the video you posted... are you absolutely sure you are running that card at bone stock factory settings?
For all we know you might have Afterburner setting the fan speed to some artificially low value instead of "Auto" and the fan never ramps up when the test starts and the GPU load hits, or it even might be something as silly as the version of Afterburner you're using might not play nice with that particular card. It could even be that you have some settings from a previous card that you tested and they're saved in Afterburner being applied right at bootup, and that's what's causing the bad results.
Make absolutely certain fan speed is set to auto. Hell, make sure Afterburner isn't even loaded, and make sure the Catalyst defaults are set before you try to test again.
For all that's going on here, this might just be a big misunderstanding because of a small testing oversight.
I will check this out when I get home. But I am pretty sure clock speed is correct. I checked it and it was 890 or 895. But I will check the fan settings
check it for sure..at that temperature, the fan should sound like an airplane on takeoff....and I dont hear it at all in that video....
