Is it possible to RMA this?
erorr404
My two year old MSI 648 Max-L has tons of issues, but I'm not sure whether it's possible to get it replaced because of them.
I can't overclock anything. I can only change the FSB on my CPU by a few MHz without it becoming unstable. I tried this same CPU on another motherboard and it easily goes past 153 MHz on stock voltage while being perfectly stable. With this motherboard, it's unstable at 136 MHz.
I can't change RAM timings or frequency either. Not only can I not overclock the RAM (168 MHz is unstable, while the default of 167 MHz works perfectly) or timings at all without getting memtest errors, I can't even raise the voltage while everything else is at stock without errors. Even if I raise CAS to 3.0 (stock is 2.5) with everything else being default, I get errors in memtest.
Obviously something's wrong with the motherboard, but is it possible to RMA it to them if everything works without issues at stock speeds?
but what will i say to them? my motherboard doesnt want to overclock? that wont work, as it's not guaranteed to.
No. Don't RMA it even if they'd let you. No OCing ability is no reason to RMA.
If you do get errors at stock and you're sure it's the mobo, that's a different story.
I think this is good enough reason to RMA it. Just tell them this and I am sure it should work. Don't even mention anything about overclocking. Just say the MB is not performing to what it is supposed to as you are getting errors by even changing the voltage a bit. I think MBs manufacturers have changing the voltage up to a certain point a part of their selling points.
Good luck.
ahh, but i would get errors without overclocking as well, would i not?
since all of the RAM in the motherboard runs at the same timings and speeds, this means that if i have one stick of RAM that's rated at CAS 3.0, and one stick of RAM that's CAS 2.5, both of which work fine when they are alone, i will get stability issues and errors in memtest when both of them are in. another example can be if i have a stick that's 2.5 V at stock and another one that's 2.6 V at stock - i will get issues with both of the RAM's plugged in, as i would have to run it at either 2.6 V or 2.5 V.
this motherboard, which gives errors even with the slightest change in voltage or timings, wouldn't support two sticks that work perfectly and should work on this board according to their manufacturers.
Good luck.
so, i should be covered if i get issues when loosening timings and raising the voltage? it is obvious that there are issues with this motherboard, as CAS 2.5 RAM really shouldnt produce errors at CAS 3, and as 2.5 V RAM shouldn't produce errors 2.6 V, but im not suer if this is covered, since everything works error-free at exact stock settings.
opps, double post.
I'd give the RMA a try. Not sure if it is worth it for a board that old. Just buy a new one, or get a cheap one off the forums :). I think setting memory timings/voltage is something that should be covered by an RMA.
