Typical response from non windows environments....."You're doing it wrong"
Can try open it with wordpad . but don't save it right after .. it will screw up your file![]()
Wow thank for all the suggestions.
There must not be much exciting stuff to talk about![]()
I'm a big windows/ MS fan and I have to say they got it wrong here, it is pointless having two characters to represent a new line and the proper way of doing it within visual studio is to use Enviroment.NewLine which is way overboard!I second Notepad++ for FAH log files and config files from Linux clients.
FYI jebo, the file would look fine if you viewed in from Linux using cat or one of the text editors. I know you love to bitch about Linux, but this one is not Linux's fault.
