forcemac101
- Feb 28, 2001
Alrighty...just got a new system put together, and am curious about find some internal USB3 cables that plug into the header. I have an older ATCS-101 Coolermaster with old school USB plugs on the front...luckily the are mounted to a nice aluminum frame and the cables are just a pair of USB extension plugs on one end with sort of flush monuted plastic sides that allow them to screwed into the case. The other end is your standard USB2 header...
What I am looking for is something similar on the USB3 Front.....anyone ever see internal header cables? Can't seem to find any with a quick search around? How deep do you have to dig?
