- May 24, 2006
I have maxed the 4 SATA ports on my current motherboard in my WHS. Is there a decent and cheap PCI or PCI-e anyone would recommend for adding more internal SATA ports to their WHS?
lol. Thanks. I don't know if I need 8 ports. I'll look into their 2-4 port cards maybe. Is supermicro the brand to go to then?
AFAIK, they really don't have 2-4 port cards. Those Supermicro cards are found in many WHS setups.lol. Thanks. I don't know if I need 8 ports. I'll look into their 2-4 port cards maybe. Is supermicro the brand to go to then?
Thank you for the kinds wordsDanny's got good taste.
Stupid question, but what's the point of those expensive >$100 cards if youre going to be using WHS and therefore no RAID?
The thing with PMs is that they're pretty damn slow considering that five drives are sharing the same port. Not to mention that Silicon Image chips are slow.What about Sil-3132 card?
It does support PM ware (one to five)
No tax with Amazon:
http://www.amazon.com/gp/offer-list...w?ie=UTF8&qid=1282153578&sr=8-4&condition=new
With which card?In MAC and PC, pp use RAID0 out of PM and get over 220MB/sec
That's not what you recommended though. You recommended software based PM controller that uses a chipset known for being fairly slow.Lately there is driver-less hardware raid PM controller that guarantees over 220MB/sec with RAID5 (must use 7200rpm drive)
Here is the card will give you over 200MB/s in SW raid 0:
http://www.sansdigital.com/adapters/ha-dat-4espcie.html
You're right about the PM... it's slow but 45MB/sec RAID5 is easily obtain-able
This speed more than enough for WHS
One thing I don't get, with WHS application why that you need over 200MB/s transfer rate with RAID array?
EDIT: @ DATOptic.Support
Your posts so far in the other threads remind me of a poster names "Firewire2". Any relations?
