- Jan 8, 2008
I keep seeing a ton of sites that recommend using a certain set of TLDs for internal domains. I'm quite confused since nothing seems to be giving a completely direct & concise answer.
What is considered the best practices for naming an internal domain?
Should I utilize my "owned" personal domain name with a subdomain or make a unique one?
If I do use a registered domain name, does the subdomain need to be added to the internet nameservers I use?
Any other advice?
Any other advice?
